replaced ignition switch..Still no start?
1992mustangLX
65
So the kid who owned before me had the car hooked up to a rocker switch to start the car. The switch went directly to the battery and the starter solenoid, which means you can crank the motor even if the key is not on run. In order to start it you turn the key to the run position and use the switch. Also you dont need the clutch to start it. I want to fix it so it functions properly. I replaced the ignition switch figuring the kid just didnt want to bother with it but it did not work. Where else can i look to try and remedy this? Any help would be appreciated! Thanks
It sounds to me like the kid thought it would be cool to start the car like that. Sounds like a dumb idea if you ask me. Im sure the old switch was fine and he just cut some wirres. Thats why it wouldnt work that way. Unfortunately you will have to go back and see what wire goes where. Wiring nightmare thanks to a dumb idea
The switch that was in there was actualy junk which really made think that that kid just didnt know what he was doing and the new one would do the trick. When i went to take the old one out i saw it had been zipped tied on to keep it together. I traced all the wiring but dont see any bad conections anywhere. Are there any relays or fuseable links i should sheck? thanks for your help
No Crank checklist for 5.0 Mustangs
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order. The clamp on with 2 bolts battery terminal ends are a know problem causer.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .5 volts across a connection indicates a problem.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help for help troubleshooting voltage drops across grounds.
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
Diagram courtesy of Tmoss &Stang&2birds
attachment.php
See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars
See http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars.
See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) If that doesn't work, use a jumper cable from the positive lead on the battery direct to the starter post where the big wire from the relay connects. If it cranks then, it is the power wire from the relay gone bad. This will be hard to do, since there isn't much room to do it.
8.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
jrichker: your the man. THanks for the great info. I checked everthing and the problem lies between the relay and the switch, but next on my list is the clutch interupt switch which you have just brought to my attention in your response! Thanks and ill let you know how i make out testing and possibly replacing the switch.
