replacement roller tips for roller rockers??
the roller that acts as the fulcrum has a c-clip, but i am needing the little roller on the tip that sits on the valve stem, it looks like it has a pressed fit pin holding it in.
alot of companies sold individual rocker arms, but the 1.73 rocker arm i have didnt come individually. and i dont want to buy a new set, i may just go stud rockers.
I understood what you were talking about... I quickly searched and saw one of the "big" catalog stores sells them individually for 60.00 each. DAMN!
You could go that route or as you suggested... go stud mounted... or even shaft mounted for more stability.
I had a problem like this several years ago. I had a pair of Crane/'93 Cobra rockers with pitted tips. I made the mistake of going through the Ford Parts department to get them at $40 a piece.
Summit sells the same thing individually for $20 each, part # CRN-44746-1.
