Replacing front struts
Black GT
148
9
28
Jacksonville, Florida
Its time to replace the front struts on my 2001 GT. The PO lowered my car I think 2 inches. It has gotten to where almost any bump in the road the top of the tire rubs on the top of the fender liner. Question, I am pretty sure just regular stock GT shocks are what I need to replace the existing shocks on the car but wanted to check before I purchased them. I do not think the special struts are used to lower the car. Any advice is welcomed. The front tire size is 245/45zr/17.
Ride quality is a function of both the springs and the struts, while ride height is solely on the springs; oftentimes lowering springs use higher spring rates than normal (meaning the spring pushes back harder when compressed), which does result in a harsher ride. You need a better strut to dampen that.
I'm lowered about an inch (Ford Racing 'B' springs) and with basic KYB struts (under $300 for a shock/strut set), it's still pretty harsh; I'd probably aim more for the mid range (Strange/Koni/Lakewood in the $400 ish range), on up to the Bilsteins (more like $700), which were apparently OE on the 03/04 Cobra.
Reactions: Black GT
I got some Tokico shocks and struts for around 150, they've lasted a long time and ride great. Good choice if you're on a budget.
Reactions: Black GT
I believe I had the Koni set when I had my 88 GT. I was on a budget and I got Koni orange shocks (forgot which model) with the Eibach Sportline springs. I remember enjoying the car that way so I think you would appreciate the lowering struts better to dampen your ride some more than the stockers would.
I have the Koni orange STR.Ts on my 2K. They are meant for an OEM or lowered car. They are the budget priced Konis. I like them with my OEM springs, but "ride" is a matter of personal preference. IMO, using stock replacements will shorten their life due to the lowered ride height and you'll be back looking for struts in a short time...read the manufacturer fine print and purchase something meant for a lowered suspension. Cheers!
Reactions: JCBeaver
This is pretty much my set up on my 03, can’t complain unless it’s speed bump time....
