replacing quad shocks with solid bar?
  • Thread starter Thread starter sgarlic
  • Start date Start date Nov 18, 2006
  • 3
1 of 3 Next Last
sgarlic
3,085
Nov 18, 2006
  • Nov 18, 2006
This is for my buddy who bought my old '88 GT. He removed the quad shocks, and says he feels the rear end floating a lot now. His dad is a fabricator, and said he wants to have him make some sold billet bars to put in place of the quad shocks. I would think this would be very hard for the rear end and basically eliminate the possibility of it flexing if necessary.
Is this a common thing to do? Are there benefits to this? Or would it be better for him to just leave the quad shocks off and put nothing else in their place?
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Nov 18, 2006
  • Nov 18, 2006
that would be the stupidest thing to do IMO....I would rather have no shocks and bounce all over than have no rear suspension at all
4dStang
Banned
Oct 23, 2002
718
Near St Louis, Missouri
Nov 18, 2006
  • Nov 18, 2006
I think that the steel would tear the connectors. I have upper/lower CA's and removed my quad's. I would like to add a panhard bar to my four link but I have no problem so far after adding subframes and re-enforced Torque boxes.
Chris
gruvee87vertgt
20+ Year Stangneter
Oct 7, 2003
272
26
28
Chicago, Il
Nov 18, 2006
  • Nov 18, 2006
We should all stay away from your friends dad's shop......what next replace the Struts and Shock with billet bars?
HISSIN50
34
129
Nov 18, 2006
  • Nov 18, 2006
Andy, I agree that this is not too hot an idea. If the dynamic of the rear axle was explained to your friend, I think he'd see why.
Aftermarket control arms are not too pricey, and should take care of the hop.
4dStang
Banned
Oct 23, 2002
718
Nov 18, 2006
  • Nov 18, 2006
My mom is a fabricator (quilts) Any body can fabricte. Get references before getting you stang fugged bad. Use tested aftermarket and ask alot of question.
Snikt89GT
264
Deland, Florida
Nov 18, 2006
  • Nov 18, 2006
When can you remove the quad shocks? I'm putting on some Pro 3i LCAs soon
Do you need UCAs and LCAs or just LCAs? What's the pro/con for removing them?
Thanks
old_blue
1,783
282
124
Nov 18, 2006
  • Nov 18, 2006
removing them allows you to run bigger wheel and tire combos. but you will increase wheel hop greatly unless you add a good uca and lca combo then those will take care of that.
D
Daggar
3,902
  • Nov 18, 2006
Hmmmm... Let's think about this for a second.
Solid bars with bushings on each end. So long as they were not setup to try and prevent lateral movement but instead... only correct rotational movement of the axle, then I don't see why it would cause any "issues". I wouldn't perform the exact same job as the buffer with the quad shocks but it would certainly limit any dipping of the pumpkin under torque.
I mean... you shouldn't have to use it to help locate the axle front to back... although the stock control arms are crappy and relatively flexible, they should do a reasonably good job of that at least.
Am I missing something?
Also... just a footnote... Upper lower control arms that use bushings that attempt to positively locate the axle laterally, often create more problems than they solve. A pan-hard bar should be used for this... not solid of spherical bushings. Sure, stiffer bushings can delay the time it takes to get into a bad situation but when you do finally reach that suspension threshold, it's often much uglier than it would have been with even the crappy rubber bushings.
MikeC
240
SLC, UT
Nov 18, 2006
#10
  • Nov 18, 2006
  • #10
Wow, you just invented the 6 link rear suspension!! Can you say bind.
71swing
199
Omaha,NE
Nov 18, 2006
#11
  • Nov 18, 2006
  • #11
The quad shock are basic shock that help resist movement in the rear, and help prevent wheel hop. They are shock for a reason. They need to have travel for when the rear end moves up and down.
since the mount for the shock are straight bolt up to the rear and frame. If you were to put solid bars on there you would prevent the rear from moving at all. It would eliminate suspension travel all together. This would make you car ride like a fork lift and would only last till the end of the street where the 1/2 bolts that mount the quads on would flex and brake.
If you bolt a solid bar inplace of the quad you could take out your springs because you would need them anymore.
Why stop there you could just weld the whole rearend straight to the frame, and eliminate the quads, springs, shocks, and the upper&lower control arms. Then i would say the rearend will never feel like its floating again.
Mustang5L5
Mod Dude
Feb 18, 2001
43,382
18,125
224
Massachusetts
Nov 18, 2006
#12
  • Nov 18, 2006
  • #12
71 swing is right
With solid bars in place of the quads, it would totally prevent any up and down movement of the rear at all. As the rear moves up and down, the shock needs to expand and contract slightly.
I don't understand why everyone is so willing to ditch the quads. Everyone gladly spends hundreds of dollars for high-performance shocks and struts and yet runs their 15-year old 100K mile quads that are oozing fluid and complains that they do nothing and takes them off.
Even with quality control arms, you should still run the quad shocks because they WORK when they are fresh.
Replacment quads are dirt cheap. Autozone sells Gabriel quads for $25 each. They are listed under "steering dampener" in their computer.
Even with quality LCA and UCA's, you should still run them.
The quad shock myth needs to die along with the TPS myth, the EGR coolant hose Myth and the dogebone on the rear myth
8950HO
658
#13
  • Nov 18, 2006
  • #13
Why did he remove them?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Nov 19, 2006
#14
  • Nov 19, 2006
  • #14
Mustang5L5 said:
71 swing is right
X2, those Myths need to die instead of getting passed on to more people that pass them on!!!
D
Daggar
3,902
#15
  • Nov 19, 2006
  • #15
So it's the difference in location of the attach points of the quads vs. the attach points for the control arms. I see what you're saying.
Not sure what this means though... Are you referring to folks that are under the impression that they will improve performance by removing these items?
z2o_what
309
princeton, WV
Nov 19, 2006
#16
  • Nov 19, 2006
  • #16
advance sells them for $15 and they come with a blue boot.
Snikt89GT
264
Deland, Florida
Nov 19, 2006
#17
  • Nov 19, 2006
  • #17
I'll add the myth of the 8mm track width with 96+ spindles
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
West Coast Best Coast
Nov 19, 2006
#18
  • Nov 19, 2006
  • #18
I would replace the quads and the regular rear shocks with solid steel pieces.Also take the front shocks out so you can pull wheelies off the line!!
sgarlic
3,085
Nov 19, 2006
#19
  • Nov 19, 2006
  • #19
He took them off because they were falling apart completely, and he's about to put some wider wheels in the back.
Thanks for the responses, I'll be sure to pass them along to him.
stang&2Birds
2,091
New England. :-) CT/MA
Nov 19, 2006
#20
  • Nov 19, 2006
  • #20
Those above "performance mods" are all PURE BS!
1) It's STUPID to remove the dogbone on a car that isn't a PURE qtr mile car. It's another classic example of people who do NOT have a Engineering degree in that subject splewing PURE BS about "performance mods". Ford put it there for a reason!
http://www.tccoa.com/articles/tranny/transmission/page17.shtml
If you don't understand EVERYTHING on that page, then do NOT screw around with something you do NOT know about.
2) Only MORONS "adjust" the TPS. Yes,only MORONS can "adjust" a NON ADJUSTABLE PART! There is NO performance mod to be seen from the TPS as long as the EEC does not throw a TPS out of range code.
http://www.veryuseful.com/mustang/tech/engine/Mustang-TPS-FAQ.html
(I design/architect computer control/response systems for a living and taught control/response systems. What "qualifications" do those other people have? Grand Master of Nintendo?)
3) Removing the EGR coolant hose with a working EGR is again STUPID. Again, clueless people doing mods when they don't have the knowledge or education.
One thing the coolant hose does is to "cool" the intake because it can get hot from the EGR. It also "helps" in some Very Rare Very Cold conditions. But, now, it's been determined/shown that in reality, under real-life conditions it's much harder go get icing in the upper than the OEM's once thought. Also, with changes in the EGR set up, better computer EGR algorithms, and better intake designs to further reducing the possibility of icing, many OEM's no longer "heat up" the intake.
Last: The same is true for removing the Quad shocks without going to a new rear-end architecture. New UCAs and LCAs (without the quads) are NOT enough to keep the rear-end in alignment under heavy acceleration! Again, unless someone has some Mechanical Engineering background (I'm "3/4th's" an ME by course credits. But, I don't need the "official ME degree". I have a MS in CS/EE/CE along with some PhD work and 8 semesters of teaching Engineering.), then do NOT go around modifying a Ford design unless you're going by a WELL RESPECTED after-market company.
Although, "well respected company" does bring up a sore point with me on how Flaming River has MORONS working for them and how they should be sued massively for selling MORONIC designs that even a 2nd year ME would know is UNSAFE!. Do a search on the Corral for my name and Flaming River.
So, even "well respected" company's (Note: C&L is NOT respected!) can sell cr*p that is dangerous!
  • 3
1 of 3 Next Last
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
Hello from California - Fox Body
  • gkomo
  • Aug 2, 2024
  • The Welcome Wagon
2K
The Welcome Wagon Sep 23, 2024
gkomo
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
