Replacing radiator
  • Thread starter Thread starter stevesmustanggt
  • Start date Start date Apr 16, 2006
stevesmustanggt
9
Mpls, MN
Apr 16, 2006
  • Apr 16, 2006
I have a leaking radiator that I'm going to replace. I'm also planning on replacing the coolant hoses and thermostat since I have the system drained. I was wondering if I should also replace the heater core at this time even though I have read and heard it is a PITA. My vert has 60K on it.
BadAndy
766
Ohio
Apr 16, 2006
  • Apr 16, 2006
I have a 95 stang with 165.000 mile and orig heater core ,pluse you have to pull the dash to replace it ,I think they will last long if you do-not put well watter in the system, I always go buy a little watter at the store and mix it with mostly antifreeze
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Apr 16, 2006
  • Apr 16, 2006
Radiator and hoses shouldn't be very hard to replace at all. Maybe a couple of hours and a roll of paper towel to soak up spilled coolant.
The heater cores in the Fox Mustangs typically go bad every 60,000 miles. That job will probably take you the better part of a weekend to get done. Also, try to find a OEM heater core, some of the aftermarket unit ones are not as durable as the factory pieces.
99 mustang gt 4.6 excess cooling system pressure
  • Blackbeauty99-4.6
  • Nov 11, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 11, 2026
LILCBRA
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
Flushing water from the radiator and block.
  • djj62478
  • Oct 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
