Replacing rear axle shaft this weekend, have a few ?s
This weekend I am replacing an axle shaft in a 95 cobra w/ABS.
The car hit a curb and bent the axle shaft. I'm also replacing the front wheel bearing and one of the bent tie rods.
So far I have:
I plan on getting:
Since this is the first time I am doing it, can you let me know if I missed anything and any gotchas I should watch out for.
Thank you !
So far I have:
- a used axle from a 96 cobra with ABS plate on it
- floor jack
- jack stands
- wheel chocks
I plan on getting:
- rear - 3 quarts Amisoil , Mobile 1 or Redline 75w-140 gear oil
- rear - Axle bearing / seal
- rear - Pan to catch old gear oil
- rear - The Right Stuff to seal housing after re-install.
- front - Tie rod
- front - Wheel bearing hub assembly
Thank you !
