Request for Roller Rocker Stud Part Number (ARP)
bretamo
122
Hello,
I am writing to request help in identifying the proper ARP roller rocker stud kit for a GT-40 M-6049-y303 aluminum heads.
I know these heads are made for pedestal mount roller rockers, but I plan to find a machine shop to drill and tap for roller rocker studs.
The plan is to install Comp Cam 1.60 roller rockers (part# cca-1331-16).
Since there are so many ARP kits to choose from, I called ARP. They were unable to help with out measurement, therefore, I thought I would write this forum to see if someone has already done the homework for the right ARP roller rocker studs to use for the GT-40 heads.
Can you help?
Thanks in advance!
I used the Comp Cams retro fit studs on my last set of heads for 8 years, and I have had a set on the GT40 irons in my Capri since 00, and they work fine.
You can look them up on Comps web site.
