Retaining Clip Bolt
You could use some squeeze tube JB Weld. Clean out the hole with brake cleaner spray...put mixed JB Weld or Quick Steel...lightly coat the bolt with grease and immediately put it in the hole before the JBWeld sets. Leave it in for about 30 mins. Take the bolt out...put speedo gear assembly in...tighten bolt reasonably.... Done.
Superglue might freeze the bolt in the hole....
