  • SN95 4.6L Mustang Tech
Rev Limiter?
  • Thread starter Thread starter joshwfl
  • Start date Start date Mar 27, 2010
joshwfl
111
  • Mar 27, 2010
I've driven the car pretty hard and have never hit the rev limiter. Last night when I left the meet at Hooters I stopped and left a little rubber by the patio, then turned the corner in the lot and floored it in 1st gear. Tach hit about 4,500 and it hit a wall and stalled, felt just like hitting a limiter. Started right up and drove home with no problems, but cruising around tonight it happened again both in 1st and second at about 4,500 RPM. Stock tune, only mods are exhaust and intake. I got an ses light, but it was for air/fuel metering. The car runs perfect otherwise, Suggestions?
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Mar 27, 2010
  • Mar 27, 2010
Post the DTC code. There have to be a dozen codes dealing with AF mixture.
Go to an autopart store and have them read the codes.
It is part of the failure management of the PCM to limit output under certain failure situations. Seams reasonable to me to reduce output instead of blowing up.
joshwfl
111
  • Mar 28, 2010
p1130
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Mar 28, 2010
  • Mar 28, 2010
Vacuum leak
Start first by looking for a vacuum leak.
>>From Ford service CD
P1130 - Lack of HO2S-11 Switch, Fuel Trim at Limit
The HEGO Sensor is monitored for switching. The test fails when the HO2S fails to switch due to circuit or fuel at or exceeding a calibrated limit.
Electrical:
Short to VPWR in harness or HO2S
Water in harness connector
Open/Shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
A fuel control HO2S PID switching across 0.45 volt from 0.2 to 0.9 volt indicates a normal switching HO2S.
joshwfl
111
  • Mar 28, 2010
That's what I was thinking after a little research. Now I need to replace the starter that ate 2 batteries today. Just crawled under it and looks like fun!
1fun281
438
Atlanta Georgia
Mar 28, 2010
  • Mar 28, 2010
Let me know when you find the problem, i have been chasing this air fuel metering code in my 99 forever
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
T
  • Locked
1990 2.3L automatic - real bad engine sputtering
  • the_steve_randolph
  • Jun 13, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2024
the_steve_randolph
T
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
Progress Thread Black Beauty: '85 GT T-Top: Winter Is Coming
  • LiquidStangs
  • Jul 30, 2019
  • 2 3
10K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 3, 2019
LiquidStangs
