  • SN95 4.6L Mustang Tech
reverse gear on 5spd
  • Thread starter Thread starter snake_eater01
  • Start date Start date Apr 12, 2007
snake_eater01
  • Apr 12, 2007
Whats up i'm new here but have been reading for awhile.
I've got an '01 GT 5spd when i depress the clutch and go to reverse it feels like the gear is still spinning and doesnt stop until i get it in. but if i keep the clutch depressed and go to nuetral and back to reverse it has stopped. as soon as i release and depress again and go back to reverse it feels like its spinning again. you know the sound of grinding gears but nowhere near as bad just mild if i only go half way into the gear while the clutch is depressed i can feel the teeth on the gear turning. its done this since the day i got it. i didnt realize until after i left the lot and went through normal driving routine. besides this everything seems fine with the tranny and clutch.
sorry if this is a dumb question but i am just trying to learn everything i can
THX
P.S. anyone here from the Fayetteville, Hope Mills NC area?
DCjuggalo
169
Charlotte, NC
Apr 12, 2007
  • Apr 12, 2007
reverse has no syncho. so you have to put it in 1st gear before you go into reverse
00GTpony
162
  • Apr 12, 2007
yeah just throw it in 5th, then straight down to reverse and it should go right in.
Mustang5L5
Mod Dude
Feb 18, 2001
43,343
18,073
224
Massachusetts
Apr 12, 2007
  • Apr 12, 2007
Reverse is synchronized on the t-45 and t-3650.
Sounds like the synchro blocker ring is getting a little worn
Tally_4.6
195
Orlando
Apr 13, 2007
  • Apr 13, 2007
I'm pretty sure it's not, mine grinds if i go straight to R. Gotta upshift then go reverse.
Mossberg
ATL, Shawty
Apr 14, 2007
  • Apr 14, 2007
The reverse in the T-45 is NOT syncronized. The T-3650 is though.
Mustang5L5
Mod Dude
Feb 18, 2001
43,343
18,073
224
Massachusetts
Apr 14, 2007
  • Apr 14, 2007
I've found more than enough info to tell me the t-45 has a synchro...including picture, but i won't say so until i am 100% sure. A lot of guys say no, but then i see a lot of info on the web saying the t-45 does have a synchro.
Here's a write-up on rebuilding a t-45 and on page 3 it shows the reverse synchro and tells you how to remove it. So things like that make me want to say the t-45 have a synchroed reverse
http://pomoforacing.com/tech/PreliminaryT45rebuild.pdf
And here is where you can buy a replacement reverse synchro for your t-45
http://www.drivetrain.com/fordcarT45.html
But i am 100% sure the t-3650 on the mid2001+ Mustangs is synchronized. It even says so on tremec's website.
http://www.ttcautomotive.com/English/products/TR-3650.asp
Stangsgrl
132
Mesa, AZ
Apr 14, 2007
  • Apr 14, 2007
Raleigh.....my parents used to live in hope mills though.
My '04, I just have to put the shifter to the left (in N) then put it in R. My bf's '03 he has to put it in 1st then R.
Mossberg
ATL, Shawty
Apr 14, 2007
  • Apr 14, 2007
On my T-3650, I can be still moving forward when shifting into reverse. On every T-45 I've ever driven, it grinds if I try to put it in reverse while the car is still moving forward. It does not syncronize.
geoffsgt
176
Baton Rouge, LA
Apr 14, 2007
#10
  • Apr 14, 2007
  • #10
Dunno about you guys, but this is impossible in my car. Shifting to 5th locks out reverse. Must move shifter into neutral (anywhere to the left of 5th really) to unlock.
stang2004
177
Northern Jersey
Apr 14, 2007
#11
  • Apr 14, 2007
  • #11
This is true. There is a safety so you dont go from 5th to Reverse instead of 5th to 4rth. Shifter needs to be moved to the left of reverse prior to be putting into reverse in some cases. It's right in the owner's manual i believe.
Mustang5L5
Mod Dude
Feb 18, 2001
43,343
18,073
224
Massachusetts
Apr 14, 2007
#12
  • Apr 14, 2007
  • #12
There is a 5-R lockout that prevents shifting from 5th down to Revese instead of 4th. It says so in the manual.
The 2001+ T-3650 has a reverse synchro, so no need to hit a forward gear anyway.
Shiroelex
There's nothing worse than aut
728
Westland, MI
Apr 15, 2007
#13
  • Apr 15, 2007
  • #13
I always hit 1st before reverse. It's such a habit of mine now, that I do it in all manual cars I get in. I did notice that it went in ALOT easier in my friend's 00 GT, after we put in a new clutch and adjustable quadrant and cable.
geoffsgt
176
Baton Rouge, LA
Apr 15, 2007
#14
  • Apr 15, 2007
  • #14
I knew what it was guys, I was just pointing it out... and curious if all stang trannies had it.
twogts4us
4,188
12
79
Dunedin, FL
Apr 16, 2007
#15
  • Apr 16, 2007
  • #15
Easiest way to tell if you have a T-45 or a 3650...try shifting into reverse. LOL
trinity_gt
3,125
81
99
Canada
Apr 16, 2007
#16
  • Apr 16, 2007
  • #16
OPer, you might try this: put your foot under the clutch pedal and pull up till it stops. This should adjust your clutch quadrant if it's not currently correct.
If the clutch has excessive freeplay, then when the pedal is on the floor, the clutch may not be fully disengaged and the guts of the transmission are still turning, making your shifting difficult. Pulling up on the pedal works the ratchet mechanism on the clutch quadrant to take up any excess slack.
Won't hurt to try.
Brute03
232
#17
  • Apr 17, 2007
  • #17
most of the time i can never get into reverse if i don't engage and disengage the clutch
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Apr 17, 2007
#18
  • Apr 17, 2007
  • #18
Mine doesnt always go into reverse smoothly. My old GT was the same way and every Mustang i have driven has been the same way.
stang2004
177
Northern Jersey
Apr 17, 2007
#19
  • Apr 17, 2007
  • #19
i always put my car into 4rth, then reverse. Its such a habit i have acquired by coming out the 5 Liter T5 world.
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
2008 Mustang Bullitt stuck in Fifth gear
  • Jester67
  • Jul 15, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 27, 2026
Jester67
