Reverse Grinding
  • Thread starter Thread starter Vaz88GT
  • Start date Start date May 16, 2012
Vaz88GT
264
27
38
May 16, 2012
  • May 16, 2012
Ever since ive owned it, it grinds when I put it in reverse. It shifts perfectly through 1-5, but 2 out of 3 times it grinds going into reverse. Its rather embarrassing, any ideas? Tranny going bad or linkage?
stykthyn
5,232
2,652
223
gainesville
May 16, 2012
  • May 16, 2012
Completely normal. Shift into another gear whilevthe car is in neutral and then slide it into reverse.
Generik
47
Brownsburg IN
May 16, 2012
  • May 16, 2012
Mine does the same thing. This suggestion works for me pretty much every time.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
May 16, 2012
  • May 16, 2012
My 96 Cobra used to do that all the time. If I rolled up an inch in 1st gear then switched to reverse it was fine....or if I stuck it in 5th, then went to reverse it would be fine.
Your reverse synchro is going bad tho. I eventually replaced mine because it got to the point where it wouldn't go in at all. I would pull with all my might and couldn't get it into reverse. It was crazy.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
May 16, 2012
  • May 16, 2012
I'm not familiar with the T45, but the T5 does not have a synchronized reverse gear. Thus, grinding noises going into reverse are very common, and happens when the car is not completely stationary or the guts are still spinning freely.
Like said above, shifting into any forward gear with the car sitting still stops the internals from spinning and eliminates the grinding sound when going into reverse (assuming you keep the clutch held in). Also, jamming the lever into reverse like you're making the trans your bitch helps, too. You get in the habit of doing this and it will never grind.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 16, 2012
  • May 16, 2012
Up into 5th first, then into reverse. The grinding will disappear.
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
May 16, 2012
  • May 16, 2012
"if you cant find 'em, grind 'em"
yelling that out the window before attempting to shift into reverse should help relieve the embarassment
SVT32VDOHC
3,501
28
119
Motor City
May 16, 2012
  • May 16, 2012
I'm not sure if it's a synchrod gear or not either...I know the new on at the dealer was pretty expensive and my trans shop put it in for me. My other one had excessive wear on the edges...didn't look too bad, but they said it was enough to give me problems because almost all of the teeth had it.
T
Treachery
148
May 16, 2012
  • May 16, 2012
As stated, shift into 5th gear and then shift into reverse.
No more grinding.
If it still grinds, then you better have it looked at.
88LX5.Oh
1,442
205
94
Arkansas
May 16, 2012
#10
  • May 16, 2012
  • #10
Like said above, shifting into any forward gear with the car sitting still stops the internals from spinning and eliminates the grinding sound when going into reverse (assuming you keep the clutch held in). Also, jamming the lever into reverse like you're making the trans your **** helps, too. You get in the habit of doing this and it will never grind.
+1. Couldn't say it any better myself.
Vaz88GT
264
27
38
May 16, 2012
#11
  • May 16, 2012
  • #11
Oh wow works like stated, of all the things ive learned here this was one of the top things lol Thank you, you saved me many odd looks!
91TwighlightGT
20+ Year Stangneter
Sep 8, 2002
1,190
375
124
Missouri
May 16, 2012
#12
  • May 16, 2012
  • #12
Mine likes to slip out of reverse unless I hold it in gear. The first time it banged out of gear I thought I hit another car or something, it was LOUD!
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 16, 2012
#13
  • May 16, 2012
  • #13
You're welcome.
Could be a lot of things. Worn sycros/blocker rings, excessive countershaft endplay, if you've got an aftermarket shifter, it could be as simple as your shift stops not being adjusted correctly.
91TwighlightGT
20+ Year Stangneter
Sep 8, 2002
1,190
375
124
Missouri
May 16, 2012
#14
  • May 16, 2012
  • #14
I actually never looked into it that closely. I probably should, but I don't spend that much time in reverse and I barely drive the car these days :0
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 5:52 PM
Don7Up
D
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
