Reving your 289's
  • Thread starter Thread starter Cobain03
  • Start date Start date May 10, 2005
Cobain03
996
Lexington, Ky
May 10, 2005
  • May 10, 2005
me and a bud both have classic stangs and both have some motor (i got 65 auto and he has 66 stick)
he revs way higher then me when driving. whats different between us to?
same intakes
same carbs
same rear gears
D
DJCarbine
392
  • May 10, 2005
This friend is me.
Anyways, I shift it normally at around 2000-2400 rpm, and when driving a little more agressivly, I wind it up to about 4k.
This is on a 3 speed manual.
Cobain03
996
Lexington, Ky
May 10, 2005
  • May 10, 2005
if i get to 4k, im runnin on all 4 barrells with the pedal to the floor at abuot 75 to 80 mph
D
DJCarbine
392
  • May 10, 2005
Nailing it from idle, your tranny shifts before you hit 4k?
MustangMatt1966
1,004
Orlando Fl.
May 10, 2005
  • May 10, 2005
i would say the difference is auto vs. stick..there is a big difference between shift points
Great68
691
Victoria BC
May 10, 2005
  • May 10, 2005
I rev my 289 to 6000. I just have to manually shift gears or else the tranny will shift itself at 4000.
D
DJCarbine
392
  • May 10, 2005
Besides the cam, are the internals just regular stock C or A code? Or is that a K code block, which has beefed up internals?
latamud
791
Tampa, FL
May 10, 2005
  • May 10, 2005
same intakes
same carbs
same rear gears
I don't want to insult your intelligence, but do you know about torque converters? They determine shift rpms for automatics. I'm not completely sure but there might be some other ways of manipulating to tranny to get it to shift at higher rpms, like a shift kit.
rbohm
6,698
550
204
tucson,az
May 11, 2005
  • May 11, 2005
actually the torque converter has nothing to do with when the trans shifts, it is the governor and the valve body programing along with the throttle position(that is the kickdown cable or rod connected to the carb) that determines when an automatic trans shifts. you can manually hold 1st and second gear if you choose, but reprograming the valve body is the best way to go for the street.
Great68
691
Victoria BC
May 11, 2005
#10
  • May 11, 2005
  • #10
C code 289, block bored 0.030", stock crank, rods, 0.030" pistons, and a full balancing.
huRACEmentPSR
Banned
Apr 2, 2005
101
San Jose, CA
May 11, 2005
#11
  • May 11, 2005
  • #11
my 289 turned like...6500 all day...but it was a k code and had solid lifters. my first 289 revved about 5200ish then power dropped, and that was stock a code with a fresh rebuild. both has 4 speeds though.
H
hobbyhorse
29
Kinston,NC
May 11, 2005
#12
  • May 11, 2005
  • #12
I've also seen that the vacuum modulator on the c-4 may need some adjustment or replacement. The engine vacuum has a lot to do with shift rpm.
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Yesterday at 2:12 PM
mattcrp1
M
