  • 1994 - 1995 Specific Tech
Riddle me this batman
  • Thread starter Thread starter parchisi
  • Start date Start date Apr 4, 2007
parchisi
519
New Mexico
Apr 4, 2007
  • Apr 4, 2007
Riddle me this, Batman
The Bosch 0 580 254 984 fuel pump sold by Steeda claims to support only 500 hp. The exact same pump sold by Accel on Summit claims to support 870 hp. ITS THE EXACT SAME PUMP!!! What gives?
T
tjh566
608
Northern Va
Apr 4, 2007
  • Apr 4, 2007
pressure, if you run a pump at 40 psi it will support so much hp, bump that up to 80psi and it will be ALOT more. See what those hp numbers as they are related to the pressure it lists.
gunmetal5.0
144
Chico, CA
Apr 4, 2007
  • Apr 4, 2007
I would think it's closer to steeda's claim for sure. Quite a gap there isn't it. Friggin' summit. If I had an application that high in horsepower I think I would use two pumps anyhow. One to pull one to push. A holley blue and red for instance.
parchisi
519
New Mexico
Apr 4, 2007
  • Apr 4, 2007
Here's the summit description for it:
These powerful ACCEL high pressure electric fuel pumps flow 435 lbs./hr. at 45 psi for engines producing up to 870 hp naturally aspirated, or 725 hp forced induction. ACCEL high pressure electric fuel pumps give you awesome flow from a name you trust--what more could you ask for?
http://store.summitracing.com/partd...4294839053+4294836965+400020+115&autoview=sku
Here's the steeda one:
Product Details
Bosch Pump flows 44 gal./hr at 72psi. Perfect for custom fuel system. Supports 450-500 HP per pump. 10 amp draw, 12V. 1/2” hose inlet (connect with hose clamps). 12mm outlet. Requires adapter fitting for outlet.
http://www.steeda.com/products/bosch_inline_fuel_pump.php
I have both of these pumps in my hands right now, the numbers match and everything.
gunmetal5.0
144
Chico, CA
Apr 4, 2007
  • Apr 4, 2007
It's a conspiracy.
gunmetal5.0
144
Chico, CA
Apr 4, 2007
  • Apr 4, 2007
Just at first glance I see... Bosch as the first brand and Accel as the second...
parchisi
519
New Mexico
Apr 4, 2007
  • Apr 4, 2007
Its the exact same pump.......the summit one is actually the bosch sold by accel. Looking at the model numbers, they are the same thing.
Yeah, I got the Steeda one a few weeks ago, and decided I'd need another, found it on summit noticed the difference but figured I wait to see the actual pump, overnighted it, and now i'm looking at them both.
T
tjh566
608
Northern Va
Apr 4, 2007
  • Apr 4, 2007
my guess is just what numbers they decided to pick for a certain pressure, the 450-500 is probly for the stock pressure, and the 800 or w/e is prolby at 80psi, its a marketing thing to make it sound bigger.
gunmetal5.0
144
Chico, CA
Apr 4, 2007
  • Apr 4, 2007
That sounds like a reasonable explanation. I still say you start crackin' skulls parchisi.
parchisi
519
New Mexico
Apr 4, 2007
#10
  • Apr 4, 2007
  • #10
That makes sense except that the Accel one says 45 psi for 870hp, and the steeda one says 72 for 500hp...?
gunmetal5.0
144
Chico, CA
Apr 4, 2007
#11
  • Apr 4, 2007
  • #11
Sounds like they're trying to use reverse psychology on those pumps. Hmmm.
T
tjh566
608
Northern Va
Apr 4, 2007
#12
  • Apr 4, 2007
  • #12
it says the flow rating at the psi, not the hp rating, at higher psi some pumps dont flow the same numbers, usually less flow higher psi.
parchisi
519
New Mexico
Apr 4, 2007
#13
  • Apr 4, 2007
  • #13
Ok, I guess I'll just run both of these suckers then. Thanks for clearin things up.....a little. I still got half a mind to go kneecap a couple peeps at Summit though...they also sent me a couple other parts that are NOT what I ordered.
(if you are an employee at Summit, this is not a threat, I was only joking...haha...hehe...don't sue me)
D
DocZG
72
San Antonio, Texas
Apr 5, 2007
#14
  • Apr 5, 2007
  • #14
yes at the higher PSI the pump only moves about 308 lbs (44gal x 7lbs per gal) of fuel so thats y its different.
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
