  • SN95 V6 Mustang Tech
Right Side Header....HELP
  • Thread starter Thread starter slowfashow
  • Start date Start date Jan 9, 2010
slowfashow
61
29Palms california
Jan 9, 2010
  • Jan 9, 2010
Today we were installing a set of JBA cat4ward headers on my 04 V6. We managed to get the left header in with no problems but as soon as we were about to take the right side header off we noticed its attached to a metal hose. We cant think of a way to get in there to disconnect. Im wondering if maybe I hve to take off the wheel to work under the wheel well. If anyone has some tips that would be helpful. And I am driving my car with one stock manifold and the other header installed. will that mess anything up?
shine1stang
30
  • Jan 10, 2010
yeah that the egr tube and it totally sucks. If you have pb blaster spray the crap out of it, and getting a wrench on it is a pain and you may only get a quarter turn at a time. Its a pain and really no good way to do it. Just take your time.
it shouldnt mess anything up running one stock and one jba. Shorty headers are kinda a waste of money anyway. Ford has done a great job on header flow and people usually never see a gain with shorties. Good luck!!!!!
MustangLX-5.0
856
Lehigh Acres Fla.
Jan 10, 2010
  • Jan 10, 2010
I hate that tube. I had no luck getting that nut to turn. I would sugget using PB several times. Hit it with PB, wait 20 minutes then hit it again with PB. If you still cannot get it to budge, try heating it up with a blowtorch. Being careful not to burn anything else, I wouuld get that thing red hot and then try turning it with a tight fitting wrench. Tight as you dont want to round off the edges. They will bend more easily when red hot. Also, try and dab up some of the PB with a cloth before you heat. PB burns...so heat gradualy as to let the PB burn off slowly. IDK... maybe spray a little brake cleaner on before you heat to get that off, then let dry and then heat.
I had to do the same thing with the header collector nuts. Only I had a little help from an impact wrench..... slowwwly. Wish there was more I could tell you. There isnt any real easy way to get that thing off.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jan 10, 2010
  • Jan 10, 2010
Hit it with a torch until it's good and hot, then spray it with some penetrating oil. The cool oil will draw up into the threads. Be warned that it will smoke like hell and look like the car is on fire, but it helps tremendously, to do it this way. I've had great success doing this on parts that were too rusted to come apart. It'll still be a bit tight to come apart, but it should work.
slowfashow
61
29Palms california
Jan 12, 2010
  • Jan 12, 2010
thanks to all of you guys. Im ready to tackle this on Friday. I have access to a lift and pretty much all the hand/power/air tools I need. I feel more comfortable with the suggestions provided. Ill post on the outcome of Friday. Thanks Again!!
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
SN95 V6 Mustang Tech May 23, 2026
DPP
D
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 5:49 PM
85GT4V
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
Help Melted Hoses!
  • sierra.herb
  • May 1, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Aug 31, 2024
nickyb
