The month of December was mainly spent scraping together funds to take advantage of Maximum Motorsports Deal of the day.
I sold a bunch of parts dirt cheap to buy as much as I could.
I got 75% of the suspension I need.
MM Bilstein Front Coilovers
10" 350 coil over springs
MM Caster Camber plates
MM Full Length Subframe connectors
MM K-Member
MM sway bar end links for lowered cars
MM Caster camber plates
MM HD Torque Arm
MM Panhard Bar
MM 415-515 torque am springs
I had also bought some used MM HD adjustable rear lower control arms a couple months back, but since MM recently changed to a more textured powdercoat, I blasted the lowers an re powdercoated them to match.
So that leaves me needing
Bumpsteer kit, MM steering rack bushings, Front control arms, MM sports damper package and a couple of other little things.
