Rocker Adjustment Problems
  • Thread starter Thread starter Mfox89
  • Start date Start date Feb 17, 2017
M
Mfox89
20
Georgia
Feb 17, 2017
  • Feb 17, 2017
Hopefully someone can point me in the right direction on this...my setup is EDL performer heads, EDL upper&lower intake, crane hydraulic lifters, e303 camshaft, harland sharp roller rockers with stock pushrods which are 6.272..i decided to change pushrod length to trickflow 6.5..ran it hard a couple times and decided to put the stock push rods back in. Anyway, i like to adjust valves by doing 1/2 turn after zero lash but this time when i put the stock pushrods back in, all the intake valves would go a good 1/2 turn but only a few exhaust valves would STOP me at 1/4 turn! I do the TDC method and have even tried the EO/IC method. I dont know whats causing this. Hopefully one of you can help me, thanks.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 17, 2017
  • Feb 17, 2017
Michael Yount’s valve adjustment procedure
Here's an easy way to determine this. Start with the #1 cylinder. Rotate the engine with a ratchet on the crank bolt clockwise. Watch the #1 pushrods. First the exhaust pushrod will rise and fall signaling what would be the exhaust valve opening and closing if the rocker were on. As it closes the intake pushrod will rise -- keep rotating clockwise until the intake pushrod falls and is level with the exhaust pushrod - both at the same height. Both lifters are now on the base circle of the cam - both valves would be closed if the rockers were on.
Now, install both rockers. Tighten the bolts with one hand while rocking the rocker with the other hand - continue until you reach the point where you can't 'rock' the rocker any more because there's no gap on the valve stem end or the pushrod end. You are at zero lash - i.e. - no gaps. Stop tightening just as you reach this point.
Now, put your torque wrench on the bolt and tighten it to 18-20 ft-lbs while counting the number of turns it takes to reach the torque. You should hit the torque within 1/4 to 1 turn of the bolt. If it takes more than 1 turn, use a shim to raise the rocker -- each .030" shim will reduce the number of turns to torque by about 1/4 turn. If you reach the torque in less than a 1/4 turn, or you have trouble reaching zero lash even at full torque, then you'll either need longer pushrods, or to CAREFULLY remove some material from the bottom of the rocker fulcrum. Using the procedure described above, you will work through the remaining 7 pairs of rockers. If you follow the firing order, it will minimize the manual cranking you have to do to get the lifters on the base circle of the cam prior to installation of the next pair.
When I first went through mine, 13 of them took no shims; 3 of them took 1 .030" shim. Upon cranking it up, one or two of them sounded a bit noisier than I thought was right, so with the engine hot, I pulled the upper off, and the valve covers, and went through the installation procedure again. That time, 11 of them took no shims; 4 of them took one .030", and one of them took one .060" shim. And they were very quiet running.
Good luck with it.
__________________
Michael Yount - K'ville,TN 82 Volvo 242w/5.0L; 2000 Suzuki Bandit 1200
Reactions: Mfox89
JD1964
there is enough sticking out to grab on to
3,605
1,611
194
Maryland
Feb 17, 2017
  • Feb 17, 2017
Here's an easy way to try again. Rotate the crank until you see one of the pushrods all the way up. Any cylinder, doesnt matter. Then adjust the other valve for that cylinder (the one with the pushrod down). Point being, when the intake pushrod for a cylinder is all the way up, the exhaust valve for that cylinder is in position to be adjusted, and vice versa. Stick a piece of tape on the ones that are done and continue till they're all done.
Exactly how are you determining zero lash before you crank down the 1/2 turn for lifter preload? That's important too. I rotate the pushrod between fingers while slowly tightening the nut. The moment rotating resistance is felt, thats zero lash. Then crank your 1/2 turn.
Reactions: Mfox89
JD1964
3,605
1,611
194
Maryland
Feb 17, 2017
  • Feb 17, 2017
Wait wait!!! I described the method for stud mount adjustable rockers. jrichker described the method for pedestal mount rockers.
Which type do your heads have? Stud mount or pedestal mount?
M
Mfox89
20
Georgia
Feb 17, 2017
  • Feb 17, 2017
Im sorry, they are stud mount..i move pushrod up and down until i acheive zero lash. Then hit 1/2 turn
M
Mfox89
20
Georgia
Feb 17, 2017
  • Feb 17, 2017
JD1964
3,605
1,611
194
Maryland
Feb 17, 2017
  • Feb 17, 2017
Everything I see on the web about Edelbrock 5.0 heads says they are pedestal mount. Can you post pics of how your particular rocker arm assemblies mount? Show the parts installed and the head with one not installed.
Here's the Edelbrock spec sheet indicating they are pedestal mount.
http://www.edelbrock.com/automotive/misc/tech-center/install/6000/60349.pdf
Reactions: Mfox89
M
Mfox89
20
Georgia
Feb 17, 2017
  • Feb 17, 2017
I'll have to take some pics but i bought the motor like it is. The valvetrain is adjustable. I think its been modified. They're the EDL performers
JD1964
3,605
1,611
194
Maryland
Feb 17, 2017
  • Feb 17, 2017
I found some with studs. Do they look like the one pictured here?
http://www.jegs.com/p/Edelbrock/Ede...320/10002/-1?gclid=CO6hqPbQmNICFVCHswodbw4E4Q
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Feb 17, 2017
#10
  • Feb 17, 2017
  • #10
why did you change the pushrod length. did you measure using an adjustable pushrod, checker spring, and solid lifter?
M
Mfox89
20
Georgia
Feb 18, 2017
#11
  • Feb 18, 2017
  • #11
Yes they look something like that..i may pull lower intake and swap lifters around to see if it does the same thing.
JD1964
3,605
1,611
194
Maryland
Feb 18, 2017
#12
  • Feb 18, 2017
  • #12
I wouldn't move the lifters. They develop a wear pattern with each cam lobe. It's best to keep lifters where they have always been.
M
Mfox89
20
Georgia
Feb 19, 2017
#13
  • Feb 19, 2017
  • #13
Yea on the exhaust valve that dosent want to go further than 1/4 turn, i was going to swap that lifter with one of the other exhaust lifter, the one that i can get a 1/2 turn on just to see if it may be a lifter problem. Im not very mechanically inclined on this but just trying to avoid putting it in the shop but ive had little experience.
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
