rocker arm install
  • Thread starter Thread starter 2012 Mustang GT
  • Start date Start date Aug 29, 2005
2012 Mustang GT
94
Alger,Michigan
Aug 29, 2005
  • Aug 29, 2005
ok i finaly have rocker arms in. they r comp cams 1.6 pro magnums, i know that i need hardend pushrods and i have herd that i can use the stock pushrods to see if the stock length pushrod would work but how exactly do i check? and what is the exact procedure to finishing off the rockers and pushrods? the valves and springs were already put on from AFR, i just want to know what all i have to do to be able to put the valve covers on and finish putting the car back together.
thanks for all your help in advance.
chris
2012 Mustang GT
94
Alger,Michigan
Aug 31, 2005
  • Aug 31, 2005
please?
vikingpower
656
CWU Ellensburg, WA
Sep 1, 2005
  • Sep 1, 2005
your AFR heads should have come with some instructions on how to measure pushrod length, my TFS heads did. You gotta measure the pushrod length first with an adjustable pushrod length checker, then order your pushrods. If you dont, you can F up your valve guides in hurry. BTW, I got the same RR as you, they're pretty nice. If you need more help send me a message or something
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
Engine Pushrod Length?
  • foxbodyclark
  • Jan 25, 2025
Fox 5.0 Mustang Tech Jan 25, 2025
limp
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
