rocker arm install
ok i finaly have rocker arms in. they r comp cams 1.6 pro magnums, i know that i need hardend pushrods and i have herd that i can use the stock pushrods to see if the stock length pushrod would work but how exactly do i check? :shrug: and what is the exact procedure to finishing off the rockers and pushrods? the valves and springs were already put on from AFR, i just want to know what all i have to do to be able to put the valve covers on and finish putting the car back together.
thanks for all your help in advance.
chris
your AFR heads should have come with some instructions on how to measure pushrod length, my TFS heads did. You gotta measure the pushrod length first with an adjustable pushrod length checker, then order your pushrods. If you dont, you can F up your valve guides in hurry. BTW, I got the same RR as you, they're pretty nice. If you need more help send me a message or something
