  • 1994 - 1995 Specific Tech
rocker arm question
  • Thread starter Thread starter 95stangGT
  • Start date Start date Jun 20, 2005
9
95stangGT
513
Buffalo, NY
Jun 20, 2005
  • Jun 20, 2005
Is it nessesary to go through the steps in the Haynes manual for tightening the rocker arms? A mechanic friend of mine said you can just tighten them as they sit but that didn't seem right. Thanks
cavscout371
277
  • Jun 20, 2005
Your friend is a idiot dont ever let him near your car!
Follow the directions in haynes or use these valve adjustment from fti's site
cavscout371
277
  • Jun 20, 2005
Another way if they are already on and just getting noisy and you dont mind spilling a little oil take the valve covers off and lash them with it running.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Jun 20, 2005
  • Jun 20, 2005
Out of curiosity, how much oil are you talking about?
SlowGT
826
Columbia Co, PA
Jun 20, 2005
  • Jun 20, 2005
Just enough to make a mess. Get a set of 94/95 tin valve covers from a junkyard and cut the tops out only far enough to access the rockers. The amount of oil you spill will be almost none.
95stangGT --> The Haynes manual probably discusses pedestal mount rockers. Which type are you using?
9
95stangGT
513
Buffalo, NY
Jun 20, 2005
  • Jun 20, 2005
I'm referring to just the stock ones.
SlowGT
826
Columbia Co, PA
Jun 20, 2005
  • Jun 20, 2005
The Haynes manuals are usually pretty accurate. The pedestal mounts are setup a little different than the stud mounts. They use shims and a torque spec, whereas stud mounts follow the steps ordered in the previously noted link. I'm sure you could modify that procedure for pedestal mounts also, but in the end you're still stuck with shims for adjustment, and a holddown bolt that needs to be torqued.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 20, 2005
  • Jun 20, 2005
Your mechanic friend is correct
Kinda Sorta
Ford made ped rockers so the workers could just bolt them on the motor as it came down the line at the factory with no checking or adjustment needed whatsoever.
The whole system of "no adjustment necessary" depends on all parts being stock, or original Ford parts. This worked ok cause Ford knew the specs on all of their own parts so that ment the valve train specs always fell within an acceptable range.
If you've milled the heads or used different head gaskets or anything like that, then you should check things for correct valve train geometry.
Later
Grady
SlowGT
826
Columbia Co, PA
Jun 20, 2005
  • Jun 20, 2005
Kinda Sorta
Later
Grady
Well put . I've had a few of those thoughts bouncing around today, but I've been running on empty since dawn and I just couldn't get them organized
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 20, 2005
#10
  • Jun 20, 2005
  • #10
I really do know where your coming from on those "organized thoughts"
Lots of times I know the answer to peeps questions
I want to help them but I have a little difficulty
in trying to figure out how to move that thought down the line to the finger tips so it makes a bit of sense on their puter screen.
Later
Grady
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
A
Engine Genius installed oil filler above rocker arm…
  • afjLX
  • Mar 27, 2025
Fox 5.0 Mustang Tech Mar 29, 2025
nicholase
Ball Joints Question
  • 93gtmustang
  • Aug 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2025
AeroCoupe
