  • 1994 - 1995 Specific Tech
rocker arm upgrade?
  • Thread starter Thread starter 1994Vib.RedGT
  • Start date Start date Feb 8, 2006
1994Vib.RedGT
585
Denver, CO
Feb 8, 2006
  • Feb 8, 2006
On a pair of ported E7s with a cam about the same as a B-303 and a cobra intake should I stay with 1.6 rockers or go with 1.7, I was thinking staying 1.6 would probably be the best option, but im not 100% sure, thats why Im asking for help. If I should stay 1.6 is there any real advantage to getting say a set of ford racing roller rockers over keeping the stock 1.6s? thanks!
mytight95
2,605
Dothan,Al
Feb 9, 2006
  • Feb 9, 2006
the extra lift will make that cheaper cam shine..... I have the 1.7s and the B-cam, there is a noticeable difference just by bolting on the 1.7's....... IMO
jason
1994Vib.RedGT
585
Denver, CO
Feb 9, 2006
  • Feb 9, 2006
can stock valve springs handle 1.7s, and would I lose any low end torque using 1.7s over 1.6s? I chose a b-type cam over the E because of the lower end torque, so i dont want to lose that.
mytight95
2,605
Dothan,Al
Feb 9, 2006
  • Feb 9, 2006
i upgraded my springs when i put the cam in.......
jason
Zero Signal
2,633
Tucson, AZ
Feb 9, 2006
  • Feb 9, 2006
The stock springs without the spring shimmed should be fine up to .53 ish total lift. Just watch your rpms. The stock valve springs once worn for 100k miles are down to the 60-70lb seat pressure range so you want to keep it under 5500rpm if you can.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 10, 2006
  • Feb 10, 2006
I think John is right on the money and I could not agree more.
Stock springs can get tired pretty quick.
The extra ratio rr's will put more stress on the springs.
Grady
1994Vib.RedGT
585
Denver, CO
Feb 10, 2006
  • Feb 10, 2006
well, the springs I am using are stock springs off of a 45000 mi car. Either way, i should stay with the 1.6's then?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 10, 2006
  • Feb 10, 2006
Like anything else in this hobby
It depends on your long term plans
I got a thing about not wanting to put much money in a set of oem iron heads. Not saying anything is wrong with those heads
however
That opinion is based on wanting the performance that Aluminum heads can more easily give you.
So you see, E7's were only a stepping stone for me on the way to the better flowing heads.
I had a set of E7's I bought with upgraded springs that came with them. I self ported them. Had the stock valves back cut and had the same guy do a fresh v j on them. I never used anything for rockers other than oem cause the gain from upgraded rockers was not worth the buck spent to me. I had a total of about $425 in them.
I only said all that to show .............................
I can get my money back out of them with that kind of thinking.
As for your concerns about roller rockers
If you went to a 1.7 rr, the gain would be small over the oem rocker.
Your stock springs will be fine with the oem rockers and stock cam up to around 5500 rpm. With the cam, I would feel better about a spring with more beef myself.
Just a few things to show, it can save money to think ahead
Grady
1994Vib.RedGT
585
Denver, CO
Feb 12, 2006
  • Feb 12, 2006
Well the E7s are just a stepping stone for me as they were for you. Im going to use the budget build that Im doing for about 2 years or so while I work out what I want to do, whether it be build a new motor, do a good HCI on my stockblock, or buy another mustang, so if the gains are minimal, ill stay with the 1.6, thanks Grady!
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 12, 2006
#10
  • Feb 12, 2006
  • #10
I do understand and I had a lot of fun with those E7's.
It was no power house but it was lots better than stock.
Sometimes, you can run across a killer deal on 1.7 rr's and then you get that gain for an amount that is more reasonable. You also have made your E7's a bit more valuable when you wanna get rid of em.
But when new, the gain from rockers is just not worth the price to me.
Heck, you can get the same gain from a home made cai for about 1/10 of the rr price.
Good luck and have a lot of fun with the stepping stone combo
Be sure and keep us updated with your results
Grady
mytight95
2,605
Dothan,Al
Feb 12, 2006
#11
  • Feb 12, 2006
  • #11
you could pick up a set of 1.7's in the corral classifieds for around 100$ wihtout trouble.
jason
Holley High-ram tuning settings
  • spencergt66
  • Apr 1, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jun 19, 2026
spencergt66
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
R
please help 87 mustang megasquirt 2 idle problems
  • robbie5.0
  • Jun 2, 2025
Digital Self-tuning Forum Jul 18, 2025
tate302
T
Custom tune?
  • Nostang25
  • Jul 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 17, 2025
FastDriver
