Rocker Arms
ferga
22
Hi
A guy is selling me a set of 16 roller rocker arms, crane, 1.7 ratio for a $100.
Is there any performance gain? I read about 1.7 give you more lift with the same duration.
Currently my 93 has Edelbrock Performer heads and 3.73 gears, auto. If I put those rocker arms, could I lose daily driver manners? Or are they a nice improvement?
Thanks
Stock cam is .444 lift with 1.6 rockers. .444/1.6x1.7=.471 lift. It is a good mod and will gain power. You will not be able to tell the differance by driving it. This is with a stock cam correct?
Do they do tend to wear out the springs at a quicker rate for the 1.7 ratio or anything else?. Can I drive the car long distances? I've been planning a trip, 1000 miles more o less.
thanks
your lift will change to the .471 as mentioned earlier. your total duration of 262 degrees will not change. your duration measured at .050 lift will change. I recommend the 1.7's for stock cams to give it a little more character :-)
