E EmoryM 20+ Year Stangneter May 22, 2002 25 0 2 Jul 26, 2004 #1 Jul 26, 2004 #1 are rocker stud girdles worth the investment?
89CopCoupe Banned Feb 17, 2004 606 0 0 Post Count City Jul 27, 2004 #2 Jul 27, 2004 #2 Only if you are a racer at which point you would probably know the answer
EMW150 Founding Member May 22, 2000 2,020 1 46 Roaring Spring,PA Jul 27, 2004 #3 Jul 27, 2004 #3 If you're running heavy springs and spinning it high, definately. I run the Harland Sharp setup and it is very stable at high rpms. It's amazing how much rocker studs will flex when you run a heavy valve spring.
Michael Yount Mustang Master Apr 10, 2002 9,039 6 79 Charlotte, NC Jul 27, 2004 #4 Jul 27, 2004 #4 Emory - tell us more about your combo and how you use it. Rev range of the motor, cam specs and type springs....
dartman New Member Mar 10, 2004 121 0 0 cardboard box Jul 27, 2004 #5 Jul 27, 2004 #5 YES JUST LOOK AT MY PICS..http://forums.stangnet.com/showthread.php?t=486946 i got 700 lift solid roller cam with 235 lbs seat pressure its a must for me,,,go see my jomar girrdle...
U usedtobe 67p51d New Member Jul 8, 2003 208 0 0 let's tear up golfcourses and build race tracks! Jul 27, 2004 #6 Jul 27, 2004 #6 I kept busting rocker studs at 6800-7k, after installing a set of probe girdles I haven't snapped one
86Cobra Founding Member Jun 6, 2000 2,064 1 0 Phoenix, AZ Jul 27, 2004 #7 Jul 27, 2004 #7 usedtobe 67p51d said: I kept busting rocker studs at 6800-7k, after installing a set of probe girdles I haven't snapped one Click to expand... What size studs?
dartman New Member Mar 10, 2004 121 0 0 cardboard box Jul 27, 2004 #8 Jul 27, 2004 #8 HERES MY SHOT 7/16STUD ROCKERS LAST MOTOR REVVED TO 8200 RPMS..1.72 ROCKERS WITH SPRING SEAT PRESSURE OF 235LBS
