Rocker Tick
302LTDII
I have a 79' 302 that has developed some rocker tick. The motor was rebuilt 3 years, 25,000mi ago at a local well known rebuild shop. I looked under the valve cover and noticed one rocker was loose. I tried tightening the bolt but it was at its proper specifications. I checked the pushrod and it was not bent. Any ideas at what this could be?
If you can't afford new heads, i'd just port the stockers and have a machine shop do some valve work. I had my lifter collapse in my 302 one day and i just sat there swearing so darn loud cause i had major plans for the motor. I had a newer rebuilt 460 short block in my garage and built that instead to try something different in a fox, it sure worked out great. Anyways, good luck with your project.
