rockers
  • Thread starter Thread starter warriorpluto
  • Start date Start date Feb 4, 2009
warriorpluto
267
monroe.LA
Feb 4, 2009
  • Feb 4, 2009
would these be good for stock e7 heads? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=200275836890
changing these on my daily driver.
D
DJFox
36
  • Feb 4, 2009
looks as though those rockers are designed for stud mount.
The factory rockers are pedistal mount....so the answer is no they wont be a direct bolt on. yes with some machining and the installation of screw in rocker studs you can use these rockers but why?...when you can just go with a set of 1.7 cobra rockers...these will bolt down to your stock heads...the pass valve cover baffle with need to be modified to clear the new rockers.
changing out the stock springs would be a good idea too while in there.
warriorpluto
267
monroe.LA
Feb 4, 2009
  • Feb 4, 2009
so these would be the best? http://cgi.ebay.com/ebaymotors/86-9...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
warriorpluto
267
monroe.LA
Feb 4, 2009
  • Feb 4, 2009
looking around for pedestal rocker arms .....those things are more expensive than the stud and those are really cheap. like under two hundred. can anyone point to some pedestal rockers that are below $230? or what does it take to convert to stud?
D
DJFox
36
  • Feb 4, 2009
Yes those rockers would do just fine. They are original equipment on the 93 cobra
remember cheaper doesn't always mean better.
Dino Dino Bambino
1,673
90
79
Cyprus
Feb 5, 2009
  • Feb 5, 2009
Crane Cams 44746-16 - Crane Energizer Pedestal Mount Roller Rocker Arms - summitracing.com
They're exactly the same as the Cobra/Ford Racing pedestal-mount 1.7 roller rockers and cost a smidgeon under $200.
warriorpluto
267
monroe.LA
Feb 5, 2009
  • Feb 5, 2009
i ordered them last night. thanks.
D
DJFox
36
  • Feb 5, 2009
i'm glad to see you went with the cobra rockers and not those cheapo jobbies.
glad I could help!
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
  • Mindseye007
  • Aug 16, 2026
Mindseye007
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
