  • SN95 4.6L Mustang Tech
rod bearings?
  • Thread starter Thread starter snidehockey
  • Start date Start date Nov 6, 2007
snidehockey
131
Orlando, Fl
Nov 6, 2007
  • Nov 6, 2007
can you guys tell me what it sounds like when you have spun a rod bearing, or they're worn?
My car started makin some pretty obnoxious clicking noises that a buddy of mine diagnosed as rod bearings...I bought the bearings - pan gasket and oil so that we could do the job.
when we drained the pan a whopping 1 quart of oil came out...(the dipstick was reading full...I checked 3 times that week) So that was the obvious cause of this noise. We ran the oil through a paint filter and saw no metal shavings.
Our first guess was at that point to just fill it w/ the 5 quarts of oil that I got...maybe it was starved thus causing the noise. That didn't help
we spent the following 7 hours attempting to manuever the engine/tranny/oil pan to get access to the rod bearings....YEAH that didn't happen.
so I have been driving for about 2 weeks w/ no increase in the noise (in fact sometimes it lessens)
and it's most prevalent at about 2-3k rpm.
I guess I'm just looking for some opinions here on what to do...somewhat cost effectively
the noise is like a chattering that you hear primarily around 2-3k rpms w/ and w/out clutch engaged. You can sometimes hear it at idle. I can feel it lightly in the accelerator pedal. It's the clearest right before a shift when I let off the gas if I'm shifting around 2k rpm.
T
truebluedroptop
  • Nov 6, 2007
that's how mine sounded and it was a rod bearing
Flghtmstr1
572
Springfield, PA
Nov 6, 2007
  • Nov 6, 2007
How could there have only been 1 quart of oil in the pan if the dipstick read "full"?
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Y
Engine 1994 Ford Mustang Gt Rod Knock/Stuck Lifter
  • yaboity
  • Jun 7, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 8, 2025
AeroCoupe
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
