Roller cam install q...
  • Thread starter Thread starter fox racer
  • Start date Start date May 29, 2007
fox racer
577
Staten Island, NYC
May 29, 2007
  • May 29, 2007
I'm putting in a TFS stage 1 cam tomorow, in my 91 5 oh, and I have one quick question. Do I have to lube the entire camshaft (all lobes and bearing surfaces) like in a flat tappet?
vikingpower
656
CWU Ellensburg, WA
May 29, 2007
  • May 29, 2007
Either lube it or dip it in oil before you install it. Also go to the hardware store and get a really long bolt (with the correct threads) that you can use as a cam install tool.
montegoman351
169
May 29, 2007
  • May 29, 2007
I like to lube the entire thing with lubriplate (white stuff). Then the sides of the lifters with oil, and the lobes with more lubriplats.
This can probably be thought of as overkill, but I'd rather be safe than sorry.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
May 29, 2007
  • May 29, 2007
I lubed mine with some white lithium grease and slid it in. It'll dissolve into the oil once you get some oil pressure going. I did put it on everything, but it was probably overkill, since it got oiled when I primed my oilpump anyway.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
May 29, 2007
  • May 29, 2007
I just put oil on the cam lobes and had no problems. I oiled the lifters also.
I have did the same places with assembly lube. Noticed no difference.
Good Luck!
90_Red_LX
668
Asheboro, NC
May 29, 2007
  • May 29, 2007
I just used assemly lube. At least put oil on it, I wouldn't feel good knowing I was going to start the car without lubing it, even if I did prime it (which I did.)
Maryland Stang
1,656
30
39
Greenville, NC
May 30, 2007
  • May 30, 2007
You should use assembly lube on the bearing surface and motor oil on the lifter lobes.
ShortThrow50
923
Pa
May 30, 2007
  • May 30, 2007
I beg to differ than you guys. The ford racing prelube says specifically DO NOT use on roller cam and lifters. Flat tappet YES. I always oiiled up the lifters good with motor oil and then the oil dripping off them will get on the cam as you rotate the crank during rocker adjustment
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
May 30, 2007
  • May 30, 2007
I agree with just plain engine oil... No break in needed for a roller cam. Prime the oil pump before cranking the engine... I use an old dizzy (removed gear) and a real STRONG drill clamped to the other end of the shaft...
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
T
Resolved No run or idle
  • Thebluefox1
  • Oct 10, 2025
Fox 5.0 Mustang Tech Nov 25, 2025
DadLife0724
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
2K
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
