Roller Rockers Do they Make alot of taping sounds ?
Doc Voodoo said:
Do roller rockers make more Noise then Hydrolic ? Just started the new engine sounds Great except the rockers are makeing a taping sound ? Is that the way or do they need adjustment
Are they hydraulic roller rockers or solid roller rockers or mechanical roller rockers?
Uh, roller rockers are roller rockers no such animal as a hyd roller rocker or a solid roller rocker maybe you meant lifters? If you rockers are making noise they might need adjustment, but as far as them being a roller rocker and making noise because of them being a roller rocker they are not going to make any more noise if not less then a regular rocker arm.
When you adjust a hyd lifter whether it is a roller or not the adjustment procedure is the same as with a stock type hydr lifter. If you increased your spring rate(valve springs) this could have increased valvetrain noise.
The only thing that might be making noise if everything is correctly adjusted is the valves closing due to increased valve spring pessure. You should not be hearing noise from your rockers.
Roller rocker arms will make more noise than stamped steel.
