Roller rockers
  • Thread starter Thread starter 87Mustang351
  • Start date Start date Jan 11, 2006
87Mustang351
220
Canada, Nova scotia, Cape Breton
Jan 11, 2006
  • Jan 11, 2006
Hey guys i got a 351 windsor bored .040 over and it has roller rockers in it some of them are loose some are tight...but 1 on each side is much more tighter than the rest the thread of the bolt is sticking up its kinda ahrd for me to explain im just learning and dont know proper names they all look the same except there 2 one on the front left and one on the back right are much tighter about 1/4 inch of thead sticking out from the nut ....the rest are level or sunk in some i cant remeber off hand right now....my cam shaft is a comp cam 280 solid lift...
Dark Knight
2,578
Chandler, Az.
Jan 12, 2006
  • Jan 12, 2006
Make sure they are out on right, one side of the trunion should have a recess for the poly lock to fit into.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jan 12, 2006
  • Jan 12, 2006
Also, are you rotating the crank to check / retighten your rockers? I believe that comp cams or crane has a detailed description on how to adjust your roller rockers properly.
Here was an install guide that I could find: http://www.cranecams.com/pdf/425e.pdf
It goes over some of the basics
Dark Knight
2,578
Chandler, Az.
Jan 12, 2006
  • Jan 12, 2006
If it's a solid lifter cam, you have to set the lash too.
http://cranecams.com/?show=faq&id=4
bullitstang1313
713
Indianapolis / Columbus, Indiana
Jan 12, 2006
  • Jan 12, 2006
You have to remember that each piston is on a different stroke this means that the valves are going to be in different positions as well. The roller rockers on the valves that are opened should feel different than those that are on valves that are closed. Ford Racing had a description on how to adjust roller rockers included in the parts book. You might be able to access it online at www.fordracing.com
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
9
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
Engine Valve and or rocker noise .....new to this but dont mind getting my hands dirty.
  • mustang matt 1993
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 1, 2024
rednotch
Engine adjust roller rockers on new 393
  • maxine-70
  • Dec 27, 2023
3K
Fox 5.0 Mustang Tech Dec 30, 2023
AeroCoupe
