Rolling The Fenders?
Shakerhood said:
That is because you are suppose to use the R58s on the Front and the M179s on the Rear. The 58s have 5.98" of backspacing and the 179s have 6.42" of backspacing.
I'm fully aware of that, but even the M179's have a tendency to look sucked in. I am trying to achieve the look of the 99+ Saleens, with the way the rim/tire combo is completely flush with the fender. I like the look of the R58/SN95 axle combo, but am just wondering if I need to roll the fender. Only one way to find out I suppose.
On a side note, when did Ford change the backspace on the R58? It has been a 5.95" backspace since '95 when they came out. Now I see that they are 5.98". WTF?
I was messing around a few days ago and mounted my front wheels (5.98 Backspace) on the rear. I am running sn95 axles and the front wheels have 255 tires mounted on them. When I stood back and looked at that set up, I realized why nobody does this. It is not even close to clearing the fenderlip. Even with 245s and completely rolled fenders I would think there would still be rubbing issues.
If you just want the wheel/tire to fill the wheel well then try bigger tires on the 6.42 wheels. I have 275s on my 17x9s in the back. Once I hammer down the fenders a little more and get the panhard rod repaired, I should have no problems. If I do I can have the 6.42 mounting surface turned down at a machine shop to tuck the wheel inboard enough to clear up the rubbing.
just some suggestions
good luck
jason
I double checked my Ford book from 01 and it says 5.98" backspacing.
Killer50stang said:
Do you have to roll the fenders for 18" saleen wheels?
This is a very tricky and involved question. I just recently went through this dilema on my lowered 93. First off, I did a Baer rear conversion which extends the rear track .20" on each side:
I also used authentic 99-04 18x9 Saleen rims. If you didn't know, the real Saleens have a front offset of 24mm and a rear offset of 12mm. When I put the rear wheel on (12mm offset) with a 265/35/18 tire, it looked great but it was extremely obvious that it would rub the crap out of my fender. I then put on a 255/35/18 tire. This time I drove it and it did rub the fender badly. I finally got a second pair of front Saleen rims and used them on the back with a 255/35/18 tire. No rubbing, no rolling the fender, and I really like the way it looks.
Bottom line: If you go with replicas (which are a 24mm for all four) and keep the rear stock track width then you will not have to roll the fender (assuming you aren't stuffing a 315 tire in there). You will likely have to run a 1/8" spacer to clear the inner fender. I didn't have to do this since my track width is .20" wider than stock.
If you use real Saleen rims you can run 4 fronts without rolling the rear fenders. If you keep the rear 12mm offset on the rear then they will work with on a stock track width and fender rolling. I just did not want to roll my fender.
If you run the sn95 rear axles with a 24mm 9" wide rim then I guarntee you would be required to roll the fender. You will not be able to use the 12mm offset rear Saleens with this setup. Good luck.
Sorry to the original poster - not trying to hijack the thread
I was planning on getting the 99-04 wheels. They're sweet. I have stock suspension. I want to convert the rear to disc and obviously do a 5 lug while I'm in the process. What do I need?
Got any pics of your car, love to see how the wheels look.
Jason :banana:
I figured out a very effective way of "rolling" the fenders. My front tires were just barely rubbing when I hit bumps so what I did was I put a block of wood on the outside of the fender then used a c-clamp and slowly tightened it so that the paint wouldn't crack... worked great!
bigsparky said:
... I put a block of wood on the outside of the fender then used a c-clamp and slowly tightened it so that the paint wouldn't crack... worked great!
So the block of wood was touching enough surface area as to distribute the pressure along the length, therefore putting more # per sq " on the pintle of the c-clamp.
Hmm, and it didn't distort the fender AT ALL huh :shrug:
I don't want to shade-tree the car at all ... it's very clean.
Hope this helps a bit.
For reference, I have an 88 GT. I am running 18x8 wheels with 235/50 18 tires, and Eibach springs, and no rolling of any of the fenders was necessary (and believe me when I say I subject my car to hard cornering).
I WILL probably have to when I upgrade to the 18x9 wheels with 265/275 width tires.
When I am finally ready to move to the 18x12 with 315/335 tires, I should have the 3" widebody flares installed. :D
If you are having serious fitment issues, a minor flaring of the fenders is certainly plausible. You can visit this site: http://www.maierracing.com/ I believe they sell 1.5" kits as well.
Umm.. i think if you're rolling your fenders there isn't a way to do it without being "shade-tree"
Yes the block of wood DID distribute enough of the weight. Think about it, which is more likely to flex.. the part of the fender that is attacehd to nothing, or the part that is attached to the rest of the fender... hmm... Physics can be your friend!
If you would like me to take some pictures of my "distorted" fender.. I'll gladly do it and prove you wrong.
By "shade-tree" I meant to imply redneck duct tape work (like you see some yahoos do). I don't know you from Adam, so it's hard to get a feel for how well your head is screwed on your shoulders. I wasn't trying to imply "shade-tree" as in, not the proper tool for the job versus brilliant improvisation.
Right, I was looking for clarification to how it worked out for you (Going back to my shade-tree comment). If the pressure being applied isn't within range for the job and the fenders strength, then the wood stabilized surface of the fender might distort a little.
I wasn't attacking you, I was inquiring how it went for you and getting a feel for how well I could trust your advice as it sounds like the easiest method to achieve good results.
I would love some good pics showing how it turned out, because without them I would have to rely on what comes out of your mouth and how credible I or anyone feels your input is.
That's all ... was only trying to get more input from you not dispute anything you were saying. :nice:
Sorry. It sounded like it was an attack to me :shrug:
This is about the best pic I can give for proof that it didn't distort the outer edge of the fender in any way. Do you see any wavyness or anything?
