Rolling The Fenders?
I know this probably won't help a lot of you guy's, but anyone in the Central New York area that needs to do this, I bought an Eastwood fender roller. Anyone can use it, just get a hold of me and we can meet up somewhere.
_jb_ said:
So I take it you did the brake upgrade and the rims won't fit? Didn't you want 18x9s?
18x9 BlackChrome Bullitts, yep ... I don't know how fitment will be, but I have a pretty windy road leading up to my house and if I get some side slosh in the rear I don't want to take any chances ... I'd rather be free and clear :nice:
When you get them on, please post pics. I am working on the same type of thing with my Cobra R's. Heres a pic of what I have.
245/45/17 with a 24mm offset wheel. SN95 axle.
I don't think I would have to roll the fenders, but I have not driven it this way yet.
If those are Factory Ford Wheels, you should not have to roll them as I have Bullitts with 245/45/17s and SN95 Axles and mine are fine.
It'll be a while before I can post pics ... car is still in the body shop for another week (theft repairs :mad: )
It doesn't look like you'll rub, especially since you went with a 245 vs a 275. Looking at your pics I could maybe see it rub a little if the rear is at full compress and side force is being applied at the same time.
Are you using any lowering springs?
Are you running the 2300K ... is it a pain, how many days for the install?
I'm running H&R race springs in back. It's lowered about an inch or so. I did the rear disk conversion a little different. I started with stock length axles and North Cobra caliper brackets. It fit good, but the rears look to sucked in, I hate that. So I bought the SN95 axles a couple years ago in Carlisle. Just now getting them on. Still need the Ford caliper bracket.
Ah, yes ...
That factory tucked-rear look :fuss: is exactly why I went with the 95 axles ... not just to achieve 5-lug and better braking.
I hate the work we hafta do just to get wheels to fit right relative to the fender lips. :nonono:
I rolled the fender lips with a body hammer, a 3 lb sledge and a plain hammer.
Jack the rear and remove the whees.
Start where you think you have the most rubbing problem and tap the inner fender up. Go slowly, just bend it a little, an keep moving along until you have the entire lip moved a bit.
Repeat as much as needed to get the inner lip to lay up to the sheetmetal above it.
Slow and carefully, and it won't show from the outside. It may break the paint, but you can cover it with spray paint or wax.
Just put in a panhard or watt's link, and you won't have to worry about side to side sloshing anymore. Every 'stang that actually gets driven should have one anyway.
9 Deuce GT said:
Yeah, they are Ford R58's. But they are 9" wide, and I seem to always see that people have trouble with this set up.
That is because you are suppose to use the R58s on the Front and the M179s on the Rear. The 58s have 5.98" of backspacing and the 179s have 6.42" of backspacing.
