Ron Morris AOD/TREMEC CROSSMEMBER W/ BRACKET 65/66
pnhd22
Changed my mind and am going with a T-5 instead. Only out of the box for test fitting. I have all original packaging and fasteners. Has a couple scuffs on it but like new as the car wasnt driven with it installed. $80.00
System knowledge about the car
Auto Suspension System which connects a vehicle to its wheels, consist of Steering System, Driving System, which make up of transmission, clutch, wheel & parts(Wheel Cylinder), tire & parts, Braking System, which make up of brake shoe, brake disc, brake pad, brake backing plate, slack adjuster arm, brake valve, brake chamber, brake hose & brake tube, vaccum booster, brake caliper, brake drum,Power Steering Pump, brake master cylinder and other parts.
:D
