Rotating mass air meter
stevesLX
373
cincinnati
I have been told stories about guys that have cold air intakes that rotate their MAF to get rid of there idle issues. I want to try this if its true but not sure how much I should rotate it and which direction to rotate it in. Should I rotate it up so the plug on the meter goes up or rotate it down?
Try turning the MAF assembly in 45 degree increments. The idea is to position the sensor in the smoothest airflow possible.
Since you probably aren't a fluid dynamics genius, it is a trial and error deal. Turn it and if that doesn't do what you want, turn it some more until you have made a complete circle.
