Hi, as some of you know, I just installed a set of Baer brakes out back of my 91. I've taken it out 4 times now, for rotor seasoning, and gentle heat cycling. The last two times (since I'm starting to drive a little harder and longer), I've noticed that the pedal gradually gets HARDER to push, and the brakes start to groan as I come to a stop.
Now here's the bad part, when I let off the brake, they still groan. And the next time I push the brake pedal, it is even HARDER.
Once the brakes reach a certain temperature, the pads don't stop touching the rotor!!! What this means is, my brakes are not fully releasing the tension, and the longer I drive, the more they grip, and the hotter they get!
Now, my theory is the heat is causing the rotor to expand slightly, but just enough to cause the pads to constantly rub the rotor (causing the friction and the groan).
But is this normal? It shouldn't be. No brake job I've ever done as done this. It's as if the piston wasn't sinking back into the caliper.
Thoughts:
Thoughts:
