  • SN95 4.6L Mustang Tech
Rough Idle + 6 Engine Codes **Help**
  • Thread starter Thread starter Team801
  • Start date Start date Jul 1, 2005
Team801
104
Salt Lake City, UT
Jul 1, 2005
  • Jul 1, 2005
Well I put my car back together today and it's running very very bad.
When I start the car it has a very tough time Idling right, at first it's low then it will "rev" up on it's own and stay at a higher idle (around 2-3K) Then drop down again, it is very irritating.
I have the following mods done to it right now.
Mac LT's
Mac O/R H Pipe
Granatelli Big M 90 MAF
70mm TB
C&L Intake plenum
SCT Xcalibrator2 which is tuned for all those mods.
If I Tune it to stock it has 11 Engine codes.
I really don't know where to start, I know it has to be something with the O2 sensors, but what could it be.....could it be a vacum leak???
If someone could please help I'd appreciate it.
I have listed the engine code below.
P0135 Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1
P0155 Upstream Heated Oxygen Sensor circuit fault - Bank No. 2.
P0443 EVAP Canister Purge Control Solenoid or Valve Faulty
P1000 OBD-II Monitor Testing Incomplete.
P1409 EGR Vacuum Regulator circuit malfunction
P1451 Lack of Response From Passive Anti-Theft System Module - Engine Disabled
Thanks
JT
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Jul 1, 2005
  • Jul 1, 2005
was that tuned with a mail order tune or on the dyno? Those EGR's can be pretty annoying, I'd definately check for any leaks around that and anywhere else.
Team801
104
Salt Lake City, UT
Jul 1, 2005
  • Jul 1, 2005
It was tuned using mail order Through Modula Madness
Also does ayoneknow where I can find a diagram of all the vacum linesin the car?
9646gt
595
Holloman AFB,NM
Jul 1, 2005
  • Jul 1, 2005
I would contact them and see exactly what changes were made in the tune if I were you!
Team801
104
Salt Lake City, UT
Jul 1, 2005
  • Jul 1, 2005
Well if I tune it back to stock the same problem happens, even worse.
I will email them today to see what was done.
02 blk GT
132
Houston TX
Jul 18, 2005
  • Jul 18, 2005
Its weird because I have some of the exact same codes being thrown....i think they might all be related some how....maybe some kind of relay or something electrical is messed up.
Brandon
BooWFO
991
Louisville, KY
Jul 18, 2005
  • Jul 18, 2005
Ok here's my thinking the o2's aren't seeing high enough temps causing the first 2 codes. Are they close enough? Did you or could you perhaps wrap the headers? Also sounds like a vacum leak to me somewhere. Double/triple check everything. Good luck
02 blk GT
132
Houston TX
Jul 18, 2005
  • Jul 18, 2005
My o2 sensors don't heat up quick enough just driving around....but when i get on the highway they work fine... i have LT headers so they are moved back alittle farther, but it just started this and hasn't always been like that with my headers..i wonder if there is some kind of relay or fuse or sensor that controls the heater circuit and maybe it went out or something? I dunno....
Brandon
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jun 14, 2006
  • Jun 14, 2006
im having the same problems!! i need to get this figured out
search function
urban96
3,464
Syracuse, NY
Jun 14, 2006
#10
  • Jun 14, 2006
  • #10
P0155 Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 2.
P0443 EVAP Canister Purge Control Solenoid or Valve Faulty.
P1409 Electronic Vacuum Regulator Control circuit fault.
^^codes im getting
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Jun 14, 2006
#11
  • Jun 14, 2006
  • #11
^ start your own thread .
you don't have to worry about the p1000, that will go away after it cycles I believe.
urban96
3,464
Syracuse, NY
Jun 14, 2006
#12
  • Jun 14, 2006
  • #12
ttt
nyuk98gt
1,427
Chesterfield, MO
Jun 17, 2006
#13
  • Jun 17, 2006
  • #13
Team801:
Your tuner can adjust an O2 sensor parameter (or two) for the long tubes. One is the delay and should be made larger for LTs. It is possible that the O2 sensors are not getting hot enough because the LT's provide more surface area near the sensors (so the heat is lost more quickly) and the sensors are farther back (gas is cooling off as it travels down the exhaust system). I have read a few threads where people have had to wrap their headers to improve O2 sensor performance. Anyway, ask you tuner about O2 transport delay and LT's and he should be able to fix the problem.
HTH,
Chris
urban96
3,464
Syracuse, NY
Jun 17, 2006
#14
  • Jun 17, 2006
  • #14
nyuk98gt said:
Team801:
HTH,
Chris
i have tried stock delay, LT delay and one twice as long as the LT delay and still no luck
urban96
3,464
Syracuse, NY
Jun 18, 2006
#15
  • Jun 18, 2006
  • #15
ok after looking over some wiring diagrams i found out their connected to the #8 fuse under the stearing wheel labeld engine controls or something like that. from the top my fuse looked fine but when i pulled it sure enough it was toast. replaced it, cleared codes and im back in business
just wanted to post this up incase anyone else has this problem now they have someplace to start
siaphysco
#16
  • Jun 18, 2006
  • #16
hey i had the same problem wen i installed my Accufab throttle body and plenum.. wut fixed it was a lil sealent on everything that i put bak on the plenum..plenums and throttle bodys r known for leaking if not sealed correctly.. try this and let me kno how it goes
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
T
Looking for some help with 2006
  • thedudeillest
  • Mar 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 20, 2026
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
