  • SVT Tech Forum
RPM launch????
  • Thread starter Thread starter EvilEyez
  • Start date Start date Feb 26, 2004
EvilEyez
103
Austin, Tx
Feb 26, 2004
  • Feb 26, 2004
I'm taking my snake to the track for the first time this weekend. Just wondering what the best rpm would be to launch at, or are any of you guys launching from idle? I've heard 2000rpm would be a good launch point for 03 cobras. What works for ya'll????????
01SilverL
262
Massachusetts
Feb 26, 2004
  • Feb 26, 2004
I usually do a side step at the rev limiter.
V
VerbalKint
36
  • Feb 26, 2004
And spin all the way through 1st?
J
JBVobra
594
Corpus Christi, Tx.
Feb 26, 2004
  • Feb 26, 2004
Depends on the tires. Stock? Maybe anywhere from idle to 3500.
Et streets? Much higher. And pray nothing snaps
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Feb 27, 2004
  • Feb 27, 2004
Stock F1 tires? Stock suspension?
1. Go around the waterbox. I repeat, GO AROUND THE WATERBOX. Doing a big smokey burnout on Goodyear F1's only makes them greasy.
2. Before staging perform just a small dry burout to clean any rocks or dirt off of the F1's. Just rev it a little an pop the clutch. You only need to turn the tires over a few times to clean them.
3. Once you stage and the light goes green, leave the line JUST LIKE YOU WERE LEAVING A STOPLIGHT ON THE STREET. Don't worry about reaction times or red lights. The hardest part is getting this 3800lbs+ beast out of the hole without wheel hop. Ease out of the hole and as soon as the clutch is fully released start adding in throttle. If the back end starts hopping, GET OUT OF THE GAS IMMEADIATELY! You don't want to break a half-shaft.
You're not going to get sub 2 second 60 foot times by dropping the clutch on your stock Goodyears with stock suspension. I was able to get a 1.9 sec 60' time using this method with the stock F1's and suspension.
U.M.
EvilEyez
103
Austin, Tx
Feb 27, 2004
  • Feb 27, 2004
Thanks Uncle Meat, I'll post my time slip numbers asap. I am running on stock suspension and tires. Just wanting to get a baseline before I get nitto Drag radials.
rdmustangkid
147
Parkland, wa.
Feb 28, 2004
  • Feb 28, 2004
Same here UM Thanks!
Vic_Ferrari
273
lake mary, FL
Mar 1, 2004
  • Mar 1, 2004
That post has to the be the funniest thing I've seen in a month......and I've seen some funny stuff.
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
  • SVT Tech Forum
