Rpm's Went Up But Car Speed Didn't Increase
Aye_plus
46
I don't even know how to ask this question much less do a search for it :D
I drove my car into work today and I noticed this problem recently but today was a good one. When I changed gears to drive away from my house, it seemed as if my speed didn't increase even when I was in 3rd gear, only the RPM's went up. So I'm out the neighborhood, in 3rd gear doing about 30mph and I punch it, just to see what happens....well, the RPM's went all the way up to 5k as if I had it in neutral but the car didn't go any faster?! I've had this 95 for about 2yrs now and it has never ran well. The previous owner removed all emission stuff including the EGR and lowered it.....a lot! It's a good looking car with all bolt on's and about 10k on both the engine and trans. Last time I had a similar problem people were telling me to clean the MAF so I did and it didn't help much. I wasted a whole can of cleaner and it looked the same so I assumed it was clean. It's running a burnt SCT chip from AM and so I'm guessing that's why the CEL doesn't come on and scanners do not work. I've done a KOEO test a few weeks ago and it did throw a few codes but they weren't anything important. Hopefully I have time to remove the chip tonight and run another test. Thoughts, Suggestion regarding this rpm issue?
Another vote here for the clutch. I've found with my Cobra clone that, if I floor it when the rpm's are too low, the clutch will slip. In my case, it would slip then catch, so the car felt like it was stuttering a bit. IMO, 3rd gear @ 30mph is a bit low to floor it, unless you've got a strong clutch. Next time, try downshifting to 2nd and punch it. You should be able to accelerate at that speed & gear without punching it, tho.
Pulled some codes when I got home but I don't think they're very helpful:
327 - DPFE or EVP circuit below minimum voltage of 0.2 volts
511 - EEC permanent Read Only Memory (ROM) test failed
512 - EEC battery powered Keep Alive Memory (KAM) test failed.
Engine on:
412 - Cannot control rpm during KOER high RPM check.
I hope it's not the clutch, I barely has 10k miles and I baby this car when I drive.....mostly because I don't know how to race in a five speed.
I'd bet my paycheck it's your clutch. You may baby the car, but the previous owner may have abused the hell out of the car (which is likely, given the modifications you've described). When my original clutch failed @ 90K miles, it did EXACTLY the things you have described... just saying.
Kerry
If it is the clutch, it going pretty fast. My RPM's were at about 2500 when the car started to move on its own as I tried to reverse out if my driveway.
I picked up some pizzas when I got off work and I parked on an incline. I park the car and leave it in 1st gear and I pull the e-brake. When I get back in to the car to leave, I release the brake and the car begins to roll back. the gear is still in 1st and the car is off, that isn't normal , right?!
Could I replace the clutch disc only or does the whole thing need to be replaced? I still haven't had a chance to look into my clutch problem, I'm sure it needs to be replaced though.
