  • 2005 - 2009 Specific Tech
Rumble betrween 65-70mph
  • Thread starter Thread starter jeremyfd
  • Start date Start date Jul 18, 2005
J
jeremyfd
UK and Spain
Jul 18, 2005
  • Jul 18, 2005
Hi
I have a GT with auto, less than 1000 miles and I have a pronounced rumble that appears betwen 65-70 mph. Changing gear or killing o/d makes no difference, so probably not engine. Ideas I have include prop shaft needs balancing, also I've seem the TSB about an exhaust vibration at 850 rpm. Any ideas??
Thanks.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Jul 18, 2005
  • Jul 18, 2005
the exhaust vibration is for the V6, not the V8
Jenns01TA
37
Jul 19, 2005
  • Jul 19, 2005
jeremyfd said:
Hi
Thanks.
Any aftermarket exhaust work done on your GT, Boss? Where is the "rumble" coming from (Engine compartment/bell housing area/Driver cabin/Center console/Rear diff/drive shaft u-joint)? Does it go away after you go above or below 65-70? Is there a small rumble in other gears that is just difficult to discern with other engine sounds?
Jenn
J
jeremyfd
UK and Spain
Jul 20, 2005
  • Jul 20, 2005
Jenn
Thanks - the noise is like a low frequency vibration that does not change frequency with speed, it builds then fades away. It sounds like a cross between a faulty wheel bearing and tyre noise on a bad road, weird. Cannot tell where it is coming from, but feels like the drivetrain. No other rumbles anywhere.
Jeremy
Jenns01TA
37
Jul 21, 2005
  • Jul 21, 2005
Jeremy
Jeremy,
Not sure when your baby was built, boss...Perhaps this
05-7-3
AXLE WHINE - VEHICLES BUILT THROUGH 11/15/2004
Hard to pin point if you can't tell where the noise is coming from. Next step in questions would be, does the RPM load act "normal" at shift points? Does it jump RPM, either up or down prior to shift? Does it hold RPM load too long before shift? Are there any other noticable operational issues? TQ Converter load?
I think I may have read here, or on another forum of a GT-AOD owner who had to receive a new tranny. If I come across it, I will post the link. I would guess if your baby has been shipped overseas, this is not a simple "Take it to the Dealership" answer.
Well, answer me back on the above and we will keep trying to pinpoint the component at least.
I feel bad that there isn't a quick answer.
Jennifer
J
jeremyfd
UK and Spain
Jul 21, 2005
  • Jul 21, 2005
Jenns05Stang said:
Jeremy,
05-7-3
Jennifer
But thanks for the thoughts! What I will do is a more complete analysis of the sound to try and really fix position, occurrence etc. So far it hasn't got any worse. And yes you're right she's overseas, in the UK in fact. Thanks again.
Jeremy
nsxer
Jacksonville, FL
Oct 1, 2006
  • Oct 1, 2006
wierd!!
My '06 does the exact same thing! I only have 1500 miles... I know that it's not common to all mustangs because I rode in my buddies '06 and his doesn't do it! HELP!!!
M
maxima
146
  • Oct 2, 2006
jeremyfd said:
Hi
Thanks.
is it just a rumble or do you feel a slight vibration , between 65 70mph . in my auto gt when im driving anything between 65 -80 mph i have a slight vibration ?
faspony
56
  • Oct 3, 2006
I had the same problem with my 06 GT, the rumbling sound and all.
I had it fixed under warranty (TSB- 05-20-2.) This TSB calls for repalcement of the ring and pinion. Check with your Ford dealer and ask about this TSB.
Problem solved
Faspony
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
H
Engine new engine troubles
  • hawkinsdrag
  • Nov 6, 2022
2K
Fox 5.0 Mustang Tech Nov 10, 2022
Monkeybutt2000
M
C
New here. Was left a 67' Mustang 347. Ready to go down the rabbit hole but don't know where to start.
  • cmille198
  • Jun 29, 2023
2K
1965 - 1973 Classic Mustangs -General/Talk- Jul 12, 2023
AeroCoupe
Engine Bad vibration 3500 RPM+
  • Vulpes5.0
  • Sep 8, 2021
7K
Fox 5.0 Mustang Tech Sep 22, 2021
Vulpes5.0
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
20K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
