Hello,
I have a Mustang 04 GT convertible... good engine but I wanted to improve handling (street only and daily driver), everything is stock except (all mods done at Chicane, a Mustang shop in the LA area...good guys) :
- first mod was GW ladder subframe connectors and MM front strut tower brace: great improvement in the feeling of the car in corners
- second mod: MM Bilstein coil-overs; my objective was good handling and good ride quality...but this is where I am having problems getting the right setup
Initially I had 325 in the front and 200 in the back. The car is well planted but the ride is just too firm for the local freeways here, especially the rear is down right scary when hitting large uneven pavement at 75+mph. Also in some corners there was an incredible banging metal noise from the rear, adding a washer on the quad shocks helped but did not solve the problem; as well as very obnoxious squeaking from the rear (pretty much all the time). I ordered 175 (MM suggestion) for the rear but while waiting the shop installed a set of 225. The squeaking noise disappeared, and also the metal banging improved (but did not disappear). When they took off the 200, there was significant rubbing between the inner spring and the black sleeve around the shock, probably the source of squeaking (the guy also mentionned that the 200 spring seemed to be fitting looser than the 225).
So here is my question, if I install the 175 will the squeaking and the loud interference with the quads come back even worst? Is anyone running this with the the fully stock quad link?
I am contemplating also going down to 300 in the front...any experience with this?
At this point I really don't want to change anything else on the suspension, and since I am still running wheel rates more than twice stock, what do you feel is the lower end for spring rates, both front and back, on a similar coil-over setup?
Thanks for the Help!!!!
