running Hot?
  • Thread starter Thread starter 91whiteponygt
  • Start date Start date May 26, 2006
9
91whiteponygt
61
  • May 26, 2006
i have a 91 gt with h/c/i swap with a 180* thermostat. car now on a hot day with a/c running runs about 210*. is this wrong? car has edelbrock perf. heads, b-303, gt40 intake/man aod, 3.73, no converters, 2 chamber flows, aslo temp gauge reads wrong sometime when using headlights, but seems to read right during the day. please help
FORCED2DV8
458
Grand Rapids MI
May 26, 2006
  • May 26, 2006
As you make more power....you will generate more heat, 210 is a little hot from where I like it, try switching to a 160 t stat, make sure your anti freeze is 20% and water is 80%, You want to stay around 180 under normal driving conditions, Do you have a electric fan or stock still??
9
91whiteponygt
61
  • May 26, 2006
have a stock fan but would take some suggestion on an electric one. will the 160* not mess up the stock computer or anything?
vristang
4,933
101
124
Seattle
May 26, 2006
  • May 26, 2006
Coolant temps of 160 - 180F can cause problems with the computer.
Your coolant level is not that low.
I would look into a good e- fan before switching to a 160F stat. There are some potential downsides to that. Downsides to an e- fan is less drag on the motor = More power (not too bad for the downside).
Also, 210 is not that hot for having a/c on. I try to keep my coolant temp around 200F. If your system is in good shape and you don't see high temps where you live then you should be able to push the temp up for increased preformance, engine durability, and decreased emissions.
Just my opinion,
jason
feifong
319
mesa
May 26, 2006
  • May 26, 2006
210 is not that bad for an h/c/i swap mine actually creeps up to 240 after my swap ive been running it with no tstat because i didnt want it to overheaat and it looks like thats what its doing.
88Stang331
239
  • May 26, 2006
Like what was said above, make sure you have the right combination of Coolant/Water (distilled). I have Stock t-stat and a head/intake swap and my car runs cooler i think.
9
91whiteponygt
61
  • May 26, 2006
what is any easy way to check and make sure my stock gauge is working properly, also i just put in a 3,000 stall torque converter
just4bob50
504
Pa.
May 26, 2006
  • May 26, 2006
Running no t-stat can actually make your engine temps higher ,because the flow rate of the coolant is increased so much that the coolant doesnt spend enought time in the radiator to cool it down enough. If you are having temps above 210 on a 180 t-stat and the guages are accurate then it is probrably time for a rad. and water pump upgrade. After I changed to a Summit aluminum rad. and high flow pump I never see temps above 195 and that when Im pounding on it. Most times it floats between 178-183.
9
91whiteponygt
61
  • May 26, 2006
the car also had 65mm bbk tb and c&l maf
HISSIN50
34
129
May 26, 2006
#10
  • May 26, 2006
  • #10
Does it seem to cool off once you get going on the highway, etc? I would want to determine if the radiator is unable to reject enough heat overall (running hot at all times) or if it's running hotter while stopped or going slow (more likely a fan issue).
Of course, things like the chin spoiler, U/D pulleys, etc all factor into considerations.
Good luck.
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
Engine Engine Bay crazy hot!
  • R82148V
  • Aug 28, 2023
6K
Fox 5.0 Mustang Tech Aug 30, 2023
Mustang5L5
