Running Lean or Rich?
  • Thread starter Thread starter crunchie12268
  • Start date Start date Aug 17, 2004
C
crunchie12268
599
Manhattan, KS
Aug 17, 2004
  • Aug 17, 2004
Keep having problems, but now I was driving it and I can hit 5,000rpms in 1st, but then I was full throttle in 2nd and it started to cut out or kinda flicker at around 3500-3700, what the hell? Does this mean I am running Lean... also, my car is heating up... slowly, it has a new radiator, water pump, thermostat. Isn't that a sign that it could be running lean.. I have the regulator set at around 38-39psi and the timing is at 14*
HISSIN50
34
129
Aug 17, 2004
  • Aug 17, 2004
are you sure it is not ignition related? you can hook up a FP gauge and watch it when your are taching out - if pressure drops, your pump or regulator are not up to par.
any codes? good luck.
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
R
Engine Fox body doesn’t run hot until I start driving
  • Rose5oh
  • Mar 17, 2025
Fox 5.0 Mustang Tech Jun 7, 2025
limp
