RUNNING PROBLEM WHEN HOT
67/98 COBRA
FLORIDA
I JUST BOUGHT A 94 COBRA 5.0L AND IT DOES NOT OVERHEAT AT IDLE.OR IF YOU DRIVE NORMAL BUT AS SOON AS YOU START GETTING THE RPMS UP AND GET ON IT THE TEMP GAUGE CLIMBS AND THE CAR STARTS BREAKING UP.WHY?
CAN ANYONE HELP WITH THIS PROBLEM?
I would do all the routine things. Replace the T-stat with a balanced Mr Gasket unit. 180°F. Flush the cooling system make sure you cycle the heat on/off. Check cooling system pressure & replace cap as necessary. Fill with good 50/50 mix of coolant and DISTILLED H20.
If none of this works i would look into the waterpump. Good luck man
I'd start with pulling codes (for the breaking up).
Consider an aftermarket gauge. The stocker is not all that accurate and can be affected by anomalies.
Here's a tech note that you might want to cruise through (for the parts that apply to you). You simply might not be able to reject enough heat if you have the air dam present.
Good luck and welcome to the boards!
