RUNNING REALLY RICH
  • Thread starter Thread starter JNB0505
  • Start date Start date Jul 13, 2009
J
JNB0505
BRAZIL IN
Jul 13, 2009
  • Jul 13, 2009
I JUST BOUGHT AND REBUILT A MOTOR OUT OF A 91 COBRA INTAKE 70 MM THROTTLE BODY E CAM NOT SURE ABOUT THE INJECTORES THEY ARE ORANGE ON TOP ANY WAY PUT IT IN MY 88 AND IT RUNS VERY RICH LIKE BURN YOUR EYES RICH THE FUEL PREESURE IS SET AT 39 WOULD MAKEING IT A MAF FIX MY PROBLEM IT RUNS GREAT WHEN I AM NUT DEEP IN IT JUST CANT CRUISE AROUND IN IT THE HEADS HAVE BEEN DECKED PORTED AND POLISHED PLEASE HELP DONT REALLY WANT TO SWAP ALL THE WIREING AND COMPUTER BUT I WILL IF I HAVE TO THANK U
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 13, 2009
  • Jul 13, 2009
Please take the caps lock off. It is very annoying to read.
The stock 19 lb injectors are orange or tan.
How do you know it is running rich? Do you have a wide band air/fuel indicator? Cars without working catalytic converters will often have irritating fumes from the exhaust.
Dump the codes to find any other problems.
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Chrome_Rust
530
Findlay, Ohio
Jul 13, 2009
  • Jul 13, 2009
Problem is the aftermarket cam/TB/Intake on a SD car. Convert it to Mass Air. Problem Solved...
Charlie
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,231
2,929
224
Vass, NC
Jul 14, 2009
  • Jul 14, 2009
As an alternative, you could get something to tune the EEC with, or pay to have it tuned. Doing it yourself would bably be more bang for your buck. Of course, learning to tune is difficult and time intensive. Still the rewards of tuning your own car are awesome.
ShortThrow50
923
Pa
Jul 14, 2009
  • Jul 14, 2009
just back the fuel pressure of some. thats what your afpr is for.
FastDriver
Sep 5, 2001
6,231
2,929
224
Vass, NC
Jul 14, 2009
  • Jul 14, 2009
Bad advice.
The computer can only compensate by about 25% total. So it can richen or lean out the fuel by about 12.5 % to each side. What he will accomplish by pulling fuel pressure is that he will lean out the rich part of his curve, but will also lean out all of the rest of his curve. For example, if he is currently rich at idle but is perfect at WOT, then pulling fuel pressure will help to bring his idle back into tolerance. However, his WOT AFR will also lean out.
Where would you rather have the correct AFR? Running rich will not cause engine damaging detonation, but running to lean definitely can. The computer will try to compensate by adding more fuel into the curve at higher rpms. However, this could take quite some time as the EEC4 doesn't change the modifiers at WOT, and the engine is rarely going to see 4-5k rpm at less than 80% load. Additionally, if the computer has already compensated by richening the mixture up top, or if he pulls more than a few psi, the computer will not be able to compensate and so he will actually force a lean condition there. That's the worst possible situation.
If, and it's a big stretch to tune this way, he has no alternative to do it the right way, then he should perform these tricks somewhere that he can be sure he isn't causing problems. Doing this on a dyno with an AFR gauge is preferred. Doing it at a track by a guy who understands what he's doing is also ok, because if it's done gradually with consistent runs, and you pay attention to the trap speed, one can ensure that they are not running the car too lean for the computer to compensate. An AFR guage, a good ear for detonation, and/or spark plug reading skills are hand when trying to attempt something as shade-tree as this. Another problem with this method is that after hours of tuning when you feel you've finally got it right, the computer will continue to adapt, and the next time at the track you'd find that the tune that was right isn't any longer.
Overall, tuning with fuel pressure alone is a band-aid compensation for a larger problem. For example, adding fuel pressure is will help to compensate for injectors that are too small - something I've done. Conversely, pulling fuel pressure will help to compensate for injectors that are too large. Still, the method clearly isn't optimal, and trying it will cause secondary issues that would concern any knowledgeable tuner.
J
JNB0505
BRAZIL IN
Jul 15, 2009
  • Jul 15, 2009
thanks for the advice and help how would i tune it by my self
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 16, 2009
  • Jul 16, 2009
Before you jump off and spend a bunch of $$$, spend 2 cents for a paperclip to dump the codes. Make sure you don't have a bad sensor or other simple problem before you go blowing money on a tweecer or other tuner device.
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
