My 86 has E7s on it,bbk shorties, and an MSD coil. After I put the e7s on it started running rich. Any ideas on what could be the problem? My timing is at 14.
My 86 has E7s on it,bbk shorties, and an MSD coil. After I put the e7s on it started running rich. Any ideas on what could be the problem? My timing is at 14.![]()
'86 with flattop pistons, no valve relieves? If so, did you check for the possibility of PtV problems? Have you performed the KOEO/KOER self tests? Manifold vacuum reading with a gauge is? .... LUK
