Running rich
Newly built 306 block: d-600procharger, trick flow heads, edelbrock performer upper/lower, shorty headers c&l 30mm, 30lb injectors, 70mm edelbrock throttle body, etc.etc. 10 degree timing having problems with engine bogging and running rich (tailpipes black) and fouling plugs. tps @.998, 40lbs fuel pressure, fmu is from pro charger, cannot find any vaccum leaks vaccum @10inches (elgin cam). have no idea where to go next :shrug: . Compression is good, engine barely broken in.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
index.php
index.php
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
attachment.php
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
I am surprised your running rich I would think lean if anything with that set up I have same injectors less the charger and I am at 41 fp with no issues are your backfires coming from the front or rear of the car ?
Try adjust the pressure up two to three psi see if it gets worse.
