Running Rough??
  • Thread starter Thread starter Quick Pony
  • Start date Start date Jan 18, 2008
Quick Pony
129
Pensacola, Florida
Jan 18, 2008
  • Jan 18, 2008
I have a 1991 LX 5.0 convertible. Car was running lousy, especially at low speeds.
I replaced the plugs, wires, cap, rotor and both oxygen sensors. Car still running rough. I unplugged the Mass Air Flow Sensor, and car runs great!
1. Would this mean the MAF sensor needs to be replaced?
2. If so, where is a good place to purchase one? The local parts store near me
wants $139.00 to $189.00 for a MAF sensor and they only come with a 1 year
warranty!
Thanks
Larry
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jan 18, 2008
  • Jan 18, 2008
I'd rather clean the wires on the current MAF first, versus replace it. Have you pulled codes at all? You can have some stored without illuminating the CEL. When you replaced the O2 sensors, did you disconnect the battery and either turn on the lights or step on the brake in order to clear the memory in the EEC? The adaptive strategy needs to relearn the sensors anytime one is replaced.
Quick Pony
129
Pensacola, Florida
Jan 18, 2008
  • Jan 18, 2008
Hi Matt,
No to all of the above. I don't know how to pull the codes.
Can I disconnect the battery and reconnect and will that clear all the codes?
Thanks
Larry
BlownFiveLiter
18
108
Chicagoland
Jan 18, 2008
  • Jan 18, 2008
You should pull codes before disconnecting the battery, to see if there are any stored. Here's a good writeup by jrichker on the procedure to pull them:
jrichker said:
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
See the "Surging Idle Checklist for help with all your idle/stall problems. The first two posts contain all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
Funanin
356
Horsham, Pennsylvania
Jan 18, 2008
  • Jan 18, 2008
If it turns out that it is the MAF, look for one either on ebay or an internet store. Should be able to get a used stock one for under 50 bucks shipped.
Funanin
356
Jan 18, 2008
  • Jan 18, 2008
http://cgi.ebay.com/ebaymotors/ford...206732455QQcmdZViewItem?hash=item180206732455
http://cgi.ebay.com/ebaymotors/5-0-...204878890QQcmdZViewItem?hash=item270204878890
Quick Pony
129
Pensacola, Florida
Jan 19, 2008
  • Jan 19, 2008
Thanks guys for your quick responses. Does anybody sell a MAF sensor with a lifetime warranty? The local autoparts stores that I have looked at only come with a 1 year warranty!!
Thanks again
Larry
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 19, 2008
  • Jan 19, 2008
Dump the codes first before you spend $$$ on a replacement MAF. You may have some other problem that cloaks itself by looking like a MAF problem.
If you get MAF failure codes (code 66), then consider upgrading to a 94-95 Mustang 70 MM MAF.
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1 *2
*1.) Metal flange adapter http://www.kustomz.com/cat3.html Buy the TR70 for $44.95. Or spend some time on eBay looking for one that may fit.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
Evidently the –A1A, -A2A, AA, etc. on the end of the part number is a minor variant that did not change the operating specs. You should be able to ignore it and have everything work good.
MAF problem code 66:
Code 66 MAF below minimum test voltage.
Insufficient or no voltage from MAF. Dirty MAF element, bad MAF, bad MAF wiring, missing power to MAF. Check for missing +12 volts on this circuit. Check the two links for a wiring diagram to help you find the red wire for computer power relay switched +12 volts. Check for 12 volts between the red and black wires on the MAF heater (usually pins A & B). while the connector is plugged into the MAF. This may require the use of a couple of safety pins to probe the MAF connector from the back side of it.
There are three parts in a MAF: the heater, the sensor element and the amplifier. The heater heats the MAF sensor element causing the resistance to increase. The amplifier buffers the MAF output signal and has a resistor that is laser trimmed to provide an output range compatible with the computer's load tables.
The MAF element is secured by 2 screws & has 1 wiring connector. To clean the element, remove it from the MAF housing and spray it down with electronic parts cleaner or non-inflammable brake parts cleaner (same stuff in a bigger can and cheaper too).
The MAF output varies with RPM which causes the airflow to increase or decease. The increase of air across the MAF sensor element causes it to cool, allowing more voltage to pass and telling the computer to increase the fuel flow. A decrease in airflow causes the MAF sensor element to get warmer, decreasing the voltage and reducing the fuel flow. Measure the MAF output at pins C & D on the MAF connector (dark blue/orange and tan/light blue) or at pins 50 & 9 on the computer. Be sure to measure the sensor output by measuring across the pins and not between the pins and ground.
At idle = approximately .6 volt
20 MPH = approximately 1.10 volt
40 MPH = approximately 1.70 volt
60 MPH = approximately 2.10 volt
Check the resistance of the MAF signal wiring. Pin D on the MAF and pin 50 on the computer (dark blue/orange wire) should be less than 2 ohms. Pin C on the MAF and pin 9 on the computer (tan/light blue wire) should be less than 2 ohms.
There should be a minimum of 10K ohms between either pin C or D on the MAF wiring connector and ground. Make your measurement with the MAF disconnected from the wiring harness.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Ignition switch wiring
Fuel pump, alternator, ignition & A/C wiring
Computer,. actuator & sensor wiring
Fuse panel layout
Vacuum routing
Funanin
356
Jan 19, 2008
  • Jan 19, 2008
or just take a peek at the filaments in the MAF and see if they are broken? There are 2 little wires if you look inside the MAF, if either one of them is broken, it is done.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
  • dan50
  • Jul 18, 2026
dan50
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
