- Jun 18, 2007
- 67
- 5
- 9
Hi guys. Recently installed a 331 stroker in my 89GT and it is running too lean. I also installed new 30# injectors and matching mass air meter. Can anyone tell me how to richen it up? Any help is much appreciated.
What MAF do you have? I know that some people have problems with their C&L units, and sometimes those "matched" meter and injector packages don't work great without a good tune. You could cheat it a bit by using an AFPR, like said above, but a tune is your best bet.
This is all assuming you are not having failures somewhere in your system.
what intake , heads? do you have a adj fp regulator ? if so what is yoru fp set at now? how do you know its lean? what fuel pump do ya have?
well fix your running hot issue and then see how it does, fix all the broke crap before you run it...
ok whats your timing at? bc if you have to much it would cause it to run hotter then normal too, allso get you a 255 intank and a adj fpr
