ok i'm having a problem with a 95 gt. When i start it up it some times stalls. Idles rough, misses and sputters, drive it same thing gas milage is crap. Heres the kicker though if i let it idle for 5 minutes it has all the power it used to have.
i check the codes and it has a few continous memory code and no koer codes.
172 - Heated Oxygen sensor indicates lean condition, right side
176 - Heated Oxygen sensor indicates lean condition, left side
181 - Adaptive fuel rich limit reached at part throttle, right side
189 - Adaptive fuel rich limit reached, left side
I did a search and found a post EXACTLY LIKE MINE and the only help it provided was check for vacume leaks, and check fuel pressure. I didn't find any vacume leakes, i don't have a gauge i just looked and listend. I will check fuel pressure tomarow, i ran out of time tonight.
What are the odds that we are throwing the same codes and it being o2 sensors??
Here is the link to the other guys post.
