Rust under vinyl
  • Thread starter Thread starter Rudey
  • Start date Start date Mar 23, 2006
R
Rudey
  • Mar 23, 2006
Hi guys.
I'm new to this forum and have been reading a lot of your posts. It's incredibly informative.
Anyway, I bought a car off ebay and took it to a mechanic for an inspection. The mechanic noticed a few bumps underneath the vinyl - mostly on one side close to the inseam. He thinks it may be rust but doesn't know.
I then took it to a body shop and the guy came out and said because the bumps were hard and didn't move when he pushed down and a few were around the inseam, he thinks it's rust but against he doesn't know.
Is there any way to "Know" short of ripping off the vinyl?
RMODEL65
313
brunswick ga
Mar 23, 2006
  • Mar 23, 2006
its rust strip the top coat it with por 15 and reapply a new one!
mfp4073
387
Hells Ditch, FL
Mar 24, 2006
  • Mar 24, 2006
Shoot, do it right, peel it off, sand and prep the roof and repaint. Tops are not hard to put on, but to do it right you need to pull the front and rear glass. The tops are cheap ($50). I have done mine twice now.
T
TheDrake1949
14
Crestview,Fl
Mar 24, 2006
  • Mar 24, 2006
Bite the bullet and peel off the vinyl, prep the roof, add new vinyl. I put off doing mine and almost lost the whole roof.
geostang351
946
Danb., CT
Mar 25, 2006
  • Mar 25, 2006
I didn't like the vinyl on mine and just removed it. Its amazing how bumpy the roof was when the factory knew that a vinyl top was going to be installed. It needed to be worked to look smooth.
My brothers that I did had the same as you. I ripped off the vinyl expecting a real disaster and it wasn't bad at all. Just scrape everything off and apply a new top, but you don't HAVE to put a vinyl top on. It can be worked to be painted.
Jsprint68
54
NJ
Mar 26, 2006
  • Mar 26, 2006
Pull the vinyl and go here!
http://www.hotrodders.com/forum/secrets-surface-rust-removal-revealed-55679.html
M
Paint and Body Restoration prob
  • Magnet86
  • Jul 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 18, 2025
2000xp8
2001 SVT Cobra Overheating Issue
  • bradencaron0
  • May 8, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 8, 2025
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
J
Car Diagnosis
  • j.2016
  • Aug 31, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 31, 2025
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
