  • 1994 - 1995 Specific Tech
S/C Install finally started
  • Thread starter Thread starter Pops Fun
  • Start date Start date Dec 30, 2005
  • 3
  • 4
First Prev 3 of 4 Next Last
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jan 6, 2006
#41
  • Jan 6, 2006
  • #41
Pops Fun said:
Hi,
I took my chip out and took it to the tuner (Pauls Automotive Engineering)and had them put a base tune in. Then they will refine it on the dyno! (my son also works there) I need a base tune because I went to a Lightning MAF and 42# injectors. The lightning MAF is tuned by the car computer not calibrated for a particular injector. At least that was the way it was explained to me.
Steve
sorry to change the subject, but you may be able to help me a ton. i have a lightning maf as well but want to switch back to my 77mm pro-m. the problem is, i dont have the stock maf plug anymore so im stuck at the moment. would you be willing to part sell the plug from yours?
Pops Fun
961
14
59
Cincinnati, Ohio
Jan 6, 2006
#42
  • Jan 6, 2006
  • #42
Hi,
If you have time to let things settle first would like to dyno and see how things work first, don't think it would be a problem.
Steve
red ink
746
Arizona
Jan 7, 2006
#43
  • Jan 7, 2006
  • #43
Green 94 5.0 said:
that depends on your ignition and fuel setup. truthfully, if you are going to baby it to the shop, the timing doesnt really matter since you wont see any boost. more information on your setup is needed to give you an accurate answer though.
I have a 255 intank, 42lb injectors, and an msd 6a ignition. i dont plan on using an fmu. nor do i plan on using a btm.
Pops Fun
961
14
59
Cincinnati, Ohio
Jan 7, 2006
#44
  • Jan 7, 2006
  • #44
I am a long way from an expert but here is my .02 Sounds good to me the only thing is you may need a T-rex or some kind of external fuel pump. I am not using the btm either. The reason for the FMU is mine is a stroked 347 with ported H/I, and should flow pretty good. I might try a run without it
Steve
Pops Fun
961
14
59
Cincinnati, Ohio
Jan 8, 2006
#45
  • Jan 8, 2006
  • #45
It's Done !!
Hi,
Well installed gauges, got the T-rex wired. turned the key and it started... then quit??
As we scratched our heads and stated at the motor we noticed a couple studs sticking out ot the intake..... Oh Yeah, the EGR plate
. Engine was sucking a lot of extra air. With that small fix it started and idled like a champ. Maybe a Wed night tune .
A poor quality video is here:
http://popsfun.com/vortech/
Stills from the process there also.
Thanks Jay (my son)
Stege
red ink
746
Arizona
Jan 9, 2006
#46
  • Jan 9, 2006
  • #46
Its LOUD!!! haha
Pops Fun
961
14
59
Cincinnati, Ohio
Jan 10, 2006
#47
  • Jan 10, 2006
  • #47
Hi,
Going for a tune Wed. evening will check back with numbers Wed. ot Thursday if everything works ok!!
Steve
HGFireHazard
460
Michigan
Jan 10, 2006
#48
  • Jan 10, 2006
  • #48
Your making me excited! I'm almost in the same spot you are, but I can't put mine on until I pull it out of Winter storage...
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jan 10, 2006
#49
  • Jan 10, 2006
  • #49
Pops Fun said:
Hi,
Steve
no prob.....you are a lifesaver. cant wait to see what it puts out tomorrow.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 10, 2006
#50
  • Jan 10, 2006
  • #50
Hey Steve
Hope you and your boys are havin lots of fun
Sounds like it is so
Keep us updated
blown 347
Grady
a50sn95
368
Elk Grove, CA
Jan 10, 2006
#51
  • Jan 10, 2006
  • #51
Pops Fun said:
... maybe I'll let my son drive it over there.
Steve
DON"T DO IT! Not worth the risk. One WOT with full timing under boost is all it takes. Really. I mean it. I broke 3 pistons with 3 degrees more timing than I usually ran.
Dennis
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 10, 2006
#52
  • Jan 10, 2006
  • #52
Dennis
Words from one who has been there and learned a thing or two.
When you see those threads where peeps make it seem like
you just bolt a blower on your car and go.
Don't get me wrong ...... I'm all for forced induction and I will be blown someday.
I think its good to see some common sense about things to do
or
not to do when getting into a blown combo for the first time.
Grady
Pops Fun
961
14
59
Cincinnati, Ohio
Jan 11, 2006
#53
  • Jan 11, 2006
  • #53
Dennis
Well I drove it home myself and will take it to the dyno today. My son is not a young pup and he spent more time on it than I did. It would have been fine. Thanks for caring.
Steve
Pops Fun
961
14
59
Cincinnati, Ohio
Jan 11, 2006
#54
  • Jan 11, 2006
  • #54
final5-0 said:
Hey Steve
Keep us updated
blown 347
Grady
Hi Grady,
Were having fun all right. Plenty to talk about and a lot of time spent together!! My wife thinks it is all about the car... she is only half right Guess, will my lightning MAF be enough or will I peg it and end up with a SCT meter?? . It is just a wait and see now.
Later Friend, Steve
Killercanary
The car that set the bar.
Altoona, PA
Jan 11, 2006
#55
  • Jan 11, 2006
  • #55
Good luck with the dyno tune today Steve! I'm as excited as everyone else to see the numbers you put down!
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jan 11, 2006
#56
  • Jan 11, 2006
  • #56
Pops Fun said:
Hi Grady,
Later Friend, Steve
i think the meter will be all right.....there is only one way to truly find out though. i would definitely go very conservative on the tune though considering the compression ratio. good luck and let us know how it goes.
Pops Fun
961
14
59
Cincinnati, Ohio
Jan 11, 2006
#57
  • Jan 11, 2006
  • #57
Hi
Drove it to work this morning man is it hard not to mash it goint to Paul's right after work..
Steve
Pops Fun
961
14
59
Cincinnati, Ohio
Jan 11, 2006
#58
  • Jan 11, 2006
  • #58
Well it didn't happen.... Drove the car to work and noticed the serpentine best had stretched and was rubbing..... OK a new best on the way over and slap it on at Paul's, no problem. Only best I could get was a belt an inch shorter, got there to short... New belt on order.... New date Friday at 3pm.. Still spent 4 hrs at the tuners looking and talking cars with my sons and the owner.
Steve
Killercanary
Altoona, PA
Jan 11, 2006
#59
  • Jan 11, 2006
  • #59
That sucks, but friday isn't too long to wait. Keep us posted!
Pops Fun
961
14
59
Cincinnati, Ohio
Jan 13, 2006
#60
  • Jan 13, 2006
  • #60
New dyno Numbers
Hi,
Went to Paul's for the dyno and after one start the computer in my car crapped out!! Anyway Paul the owner had a computer from his Roush and he let me tune with it.... Thanks Paul. Anyway the the number's, I like the increase in torque
  • 3
  • 4
M
Progress Thread Monkeybutt2000's 89 vert build thread- 408w build in progress
  • Monkeybutt2000
  • Apr 4, 2020
  • 20 21 22
72K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2026
2Blue2
Old H/c/i Installation Explanation And Pics
  • FastDriver
  • Jan 26, 2018
2K
Fox 5.0 Mustang Tech Jan 27, 2018
FastDriver
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
Need Help, Car Wont Start, I've Gone Through Both Checklists
  • 93silverlx50
  • Jul 22, 2017
  • 2 3
13K
Fox 5.0 Mustang Tech Apr 30, 2019
General karthief
Cam Install Started...
  • Three50won
  • Nov 6, 2015
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Nov 12, 2015
Unreal281
