VibrantRedGT said:This is a 347 motor correct? Hmm...I would think there is much much more in there.
sonicblue87lx said:how many pounds of boost where your running for the dyno? Im installing my blower right now im my 347 just trying to get an idea
YEAHLOH95 said:I LOOK FOR YOU TO SHOOT RIGHT TO 500 AT THE WHEELS WITH JUST A POWER PIPE OH SORRY FOR CAPS
Killercanary said:Steve, what did Paul and the others think. I kno you have worked a long time on this, and I don't want to rain on your parade but something isn't adding up. There is no reason you shouldn't have made at or much nearer to 500rwhp with your mods. The top of that graph looks weird to me for a vortech car, the HP sort of flat lines from 5250-6000 like and NA car might, but a vortech car shouldn't, at least not at that low of an RPM even with the added cubes IMO. Is the stock vortech inlet "soft" or is it a hard plastic? If it was soft maybe it was semi-collapsing on itself and starving the supercharger for air. It looks like you hit a wall at around 5250 and normally its due to something being at its limit for flow, but in your setup there shouldn't be anything that isdoing this, at least not that I can think of. I'm stumped...
. What do you think??YEAHLOH95 said:just be careful the frist time you get on it it will surprise you wha tires you running ? drag radials i hope
Lots of fun... 2nd gear is a blast, you do have to watch it though especially in a slight turn.
Expressway on ramps are a lot of fun. I was surprised that the boost really doesn't come on til you go WOT, I thought (there i go again thinking) at higher rpm you would just see it... no so. Anyway it was fun..
95cobraguy said:i would put a set of long tubes on, a 75mm throttle body, and a powerpipe to start. are those injectors sufficient enough?
the dyno will tell
